Recently purchased an 04 without a key - Ford Truck Enthusiasts Forums
Old 07-17-2014, 11:39 PM
ecidemon ecidemon is offline
ecidemon is starting off with a positive reputation.
So, I recently purchased an 04 XL that was a repo, so it didn't come with any keys. I did a search an most turned into "well you can reprogram blah blah blah"
This doesn't have a key - any ideas what the best way to get a new key cut for this thing? I don't mind paying the dealer, but I would like to know a ball park figure of what it'd cost before hand, or if there is a better option.
Thanks in advance.
Old 07-18-2014, 01:22 AM
1969furd 1969furd is offline
1969furd is starting off with a positive reputation.
dealers is about 65 to program an already cut key, so without 150 as a guess
Old 07-18-2014, 02:50 AM
thanks for the guess either way
Old 07-18-2014, 04:13 AM
db_tanker's Avatar
db_tanker db_tanker is offline
db_tanker is starting off with a positive reputation.
alot of locksmiths have the ability to program them nowadays and are generally cheaper than the dealer...something to think about.
just do a google search for a locksmith in your area.
Old 07-18-2014, 05:46 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
My dealer just cut a new key using the VIN (free), but charged $65 to program one. Once you have two programmed keys you make & program more yourself.
Old 07-18-2014, 02:25 PM
jpr38057 jpr38057 is offline
jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.
Go to a locksmith. A dealer may not be able to get the key code for your truck as we can only get key codes back 10 years. Plus you will have to fill out all kinds of paperwork.
Glow Plugs 101 Tutorial Chevy_Eater Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 41 07-25-2015 09:14 PM
High Quality Exhaust Sound Clips (Test Thread and Ideas) Drunken_Unicorn Excursion - King of SUVs 29 07-12-2015 09:11 PM
CRANK NO START!!! Possible Fuel Line Check valve...???? drain-back issues?? ol-blu 6.0L Power Stroke Diesel 8 03-29-2015 11:53 AM
Any Ford V8's with the distributor in the rear? PhatCaprice Performance & General Engine Building 16 02-15-2015 11:41 AM
3v to 2v swap? hastingspro 2004 - 2008 F150 2 06-14-2014 07:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
