Alternator - What AMP to buy?
on
A lot of guys use what they call a 3G alt. Not sure what all that is or if your computer
controlled truck would be okay with it. As it's a diesel I think it would be fine. But let
the guys that really know chime in. Rule of thumb I have heard all my life is "The
Bigger The Better". Not sure they was talkin alts though.
The most I have on my truck is the stereo system. I have 2 amps which I believe are 500w each and HID lights. The people at DB stated that I should be fine with a stock unit. I have no light dimming or nor the truck shuts off while on idle. Right now my original unit that came new with truck is putting out 11.7-12.00 and I believe it should be at 13-13.5. My batteries are brand new.
You don't want to get carried away and get something too large or you will need to change other components besides just the alternator. I still have my stock alt and I have HAM radio, Scanner, winch/compressor and I don't have an issue and I am still showing 13.8-14 while running. When it comes time to change mine, I will most likely go with another stock alt and go with it.
There is a fellow FTEr on here some where that installed a 6.0 alternator on his 7.3 also. Flip the rear of the case 180 and bolt it right up. Planning on doing this to my truck as soon as mine takes a dump. Plowing is hard on my alternators so I carry a spare in the truck all the time.
