1996 4.9 DTC p0136 02 sensor locations? - Ford Truck Enthusiasts Forums
Old 07-17-2014, 01:00 PM
JSTJ704 JSTJ704 is offline
JSTJ704 is starting off with a positive reputation.
My check engine light came on it says p0136 Bank 1 sensor 2 pretty much saying low voltage to that 02 sensor. I seen the low voltage for bank 1 sensor 2 on my scanner with live data at 0.040. others was much better. I put my scanner to record mode and sparyed carb cleaner to see if that low volts changed from a vacuum leak it didn't. I have replaced both 02 sensors in the Manifold like 2 weeks ago just to do it for mantice and today I had some good used old o2 sensors for the truck and replaced the 02 sensor on the leftside of the manifold close to the firewall no change in volts. I have not yet replaced the downstream 02 sensor yet past the cat. Now really on a oneside manifold exhust system such as my 96 4.9L 300line 6 which 02 sensor is witch? I know bank 1 sensor is closest to cylinder one. The second 02 sensor in the manfoild to the leftside facing manifold are they going to call that bank 1 sensor 2. It's kinda confusing when I have looked at other sites they refered bank 1 sensor 2 the downstream 02 past the past the cat. I know how it works on duel manifolds . But a 300 inline 6 has me confused.
Circuit
Read more at: OBD-II Trouble Code: P0136 Oxygen O2 Sensor Circuit Low Voltage (Bank1, Sensor2)
Copyright OBD-Codes.com
Old 07-17-2014, 01:03 PM
I did replace the 02 sensor fuse. Also which is odd i tryed it cold and warm on my scanner Actron auto scanner plus it will not do a 02 sensor test and everytime I ran that test on different cars it worked.
Is bank 1 sensor 2 the downstream past cat?
Old 07-17-2014, 04:55 PM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
On the 300 six
Bank 1 sensor 1 monitors cylinder 1,2,3
Bank 2 sensor 1 monitors cylinders 4,5,6
Bank 1 sensor 2 monitor the gases coming out of the main catalytic converter.
Old 07-22-2014, 03:26 PM
Awsome thanks
Old 07-23-2014, 07:44 PM
I replaced the 2nd manifold 02 sensor I don't know how many times thinking it was it. I did have anew downstream but I didn't know they call that bank 1 sensor 2. I tryed to get it out oneday with my 02 socket and couldn't get it out so I just kept sparying it with PB blaster. Well after I tryed getting it out not to long and bang I got p0136 bank 1 sensor 2 and my scanner allso said look at I think it was p2201 or and p2271 well anyway it said stuck lean or stuck rich or did not change. Well I thought it was manifold 2 cylinder 4-6 02 sensor. I never got this code intill I tried to remove the downstream. I got it out yesterday and when I got it out I seen it was smash alittle dented from me trying to use a 02 socket to get it out I used a shorty 7/8 wrench and got it. The code hasn't came back or yet anyway.All scanner I/Ms are almost complete waiting for cat mon and secondary air to complete. I don't have to worry about e-check or smog check.
Is it the 02 sensor? Dave042 1997 - 2003 F150 2 01-19-2016 09:22 PM
1996 F350 O2 Sensor Codes P135, P136, P141 and P155 jmlkicker 1987 - 1996 F150 & Larger F-Series Trucks 0 08-04-2015 12:00 AM
OBD2 code p0136 rangergolfer Ranger & B-Series 1 12-16-2011 02:36 PM
O2 Sensor help? P0136 Dabonecrusher 1997 - 2003 F150 6 01-25-2011 10:18 PM
Ford OBDII trouble codes 01silvergt 1997-2006 Expedition & Navigator 2 07-13-2005 02:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
