Tranny Temps
Tranny Temps
What is everyone seeing for Transmission temperature? My '15 runs a little warmer than the "11. I am getting up to 205F unloaded and at times higher than the oil temp. I also get 10 degree fluctuations within a matter of minutes on the highway. I initially thought the elevated temp (compared to my old '11 at a steady 192F) was due to breaking in, but now have over 1200 miles.
My dealer says there are no 2015 specs on temp range that he could find.
The thermostats in the secondary cooling system open and regulate the upper radiator temperature at 140° F. The low temperature thermostat regulates the lower radiator temperature to 113°F
The Secondary cooling system cools the CAC, Fuel, EGR, and tranny So you can see higher temps on hot days when the coolant is working hard to cool all these components. Ford using a special transmission fluid that is designed to run at these 190-205° temps.
If you are seeing much higher than 205° tranny especially for any extended periods, Then I would be concerned. But anything under 205 in these summer driving conditions seems to be with in norms
George, I am seeing the same temps you are with my 2015 F350, and thought the same thing about the temps being higher than my 2011 (from what I could remember). Also, remember that this tranny has different components from our 2011's. I'm glad I'm not the only one seeing these temps, it must be normal for the 15's.
CLK
05-25-2004 05:22 PM
ryanben
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
11-07-2003 04:58 PM
