Can you spot the difference? - Ford Truck Enthusiasts Forums
Old 07-17-2014, 01:39 AM
51dueller's Avatar
51dueller 51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
Finally got another thing done off the checklist. As with everything it always takes longer than you thought. Now can you guys spot what modifications I've done to my upper intake.
Old 07-17-2014, 04:55 AM
Gicknordon's Avatar
Gicknordon Gicknordon is online now
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
it says 5.4 for one thing...
Old 07-17-2014, 09:07 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Quote:
With a Mercury logo?
Old 07-17-2014, 09:14 AM
harleymsn's Avatar
harleymsn harleymsn is online now
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
I don't see any way I could connect that to my flathead.
Old 07-17-2014, 09:23 AM
51dueller's Avatar
A 331 is a 5.4L engine and its going into a Mercury truck so it can't just say powered by Ford. As far a changes though, it has gone under some surgery.
Old 07-17-2014, 09:52 PM
51dueller's Avatar
I think I might have forgot a piece...
Old 07-18-2014, 12:24 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
I thought it looked a little narrow. You did a great job on the cover plate. That's awesome. Looks totally factory. Any particular reason why you decided to cut a chunk out of the middle like that? How did you get the runners to seal all the way around inside? I don't know how you could weld them fully.
Old 07-18-2014, 10:45 PM
51dueller's Avatar
You don't need to have a perfect seal between the runners. The intake only moves air and all the runners pull from a shared plenum. I also had both parts planed smooth so leakage would be minimal. Air is always going to take the path of least resistance.
As for why, part is I could and I was going to be doing work inside anyways. It's usually only done with the stock HO and Cobra intakes as they fit back together better. It shifts power up the rpm range 200 rpm but allows the engine to pull farther before dying off. Also gets a little more flow out of it.
Here you can see the bottom doesn't line up quite as nice.
Finished product.
I also opened up the inlet up to 90mm. Its a little overkill but go big or go home. I think I might be the only one to go that big or at least posted about it on the internet.
I like to tinker with stuff and this has been kind of an experiment.
Old 07-19-2014, 07:17 PM
TonyB55's Avatar
TonyB55 TonyB55 is offline
TonyB55 is starting off with a positive reputation.
Nice job! I like subtle modifications like this. I'm sure most people wouldn't notice unless you pointed it out.
Finally finished my collection 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 11-09-2016 10:37 PM
Frameswap 3.0: The Reckoning 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 47 02-16-2016 07:54 PM
Chassis Dimensions 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 06-17-2015 11:34 PM
Anyone weld aluminum? 51dueller Manitoba / Saskatchewan Chapter 5 05-30-2014 11:07 PM
Battery Box Source 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-08-2010 10:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
