Engine oil temperature ? - Ford Truck Enthusiasts Forums
Old 07-17-2014, 01:22 AM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
So on our 7.3s there's a gauge on the dash with an oil picture and a L and H. Is that for temperature ? Or oil pressure ?
I've always thought it was oil pressure and I hope it is.
Anyway my point is that I've owned my truck nearly 3 years and the guy I bought it from put a tri pod pillar gauge in it. It has pyro on top. Boost in middle . And "engine oil temp" on the bottom. The engine oil temp isn't hooked up. Never has been. So my question is could I set up that gauge somehow easily ? And is there any point because like I said not sure if the one on the stock gauge cluster is for oil psi or temp. That's all. Thanks guys. !
Oh and it's a zf 5. No need for a tranny temp gauge.
Old 07-17-2014, 01:35 AM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
Stock is pressure.
You'll need to add a sender for oil temp.
Oil temp in the ZF5 is important to if you tow a lot.
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
That's pressure on the dash. I think it's just a yes or no sensor. You either have oil pressure or you dont.
I also think there's a plug somewhere near the oil filter that can be used for your oil temp. Both just things I think I remember reading. Someone here can clarify I'm sure .
Edit: Bruteford beat me to it.
Old 07-17-2014, 01:24 PM
DanielT28's Avatar
I was Reading that the plug on the oil filter housing place. Isn't actually correct temperature because it's already cool when it hits that point because it runs thru the oil cooler ? Or something rather.
And ya I do tow quite a bit of scrap metal and cars. So it probably wouldn't hurt to have a tranny temp gauge.
But what's more beneficial.? The engine oil temp gauge since I already have it !? Or tranny temp ?
Old 07-17-2014, 01:25 PM
DanielT28's Avatar
It's just not hooked up yet
Old 07-17-2014, 05:09 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
You can monitor oil temp via the PCM, with any device that communicates with our trucks o the OBD-(not-quite-)II port.
Old 07-17-2014, 09:41 PM
DanielT28's Avatar
Hmm ok. . But how about hooking up a mechanical gauge like I already have ? I'll post a pic of it.
Old 07-17-2014, 09:52 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
I have my temp gauge on a rotary switch right now I have engine water temp, transmission temp (5 speed) and rear axle temp ( I am having issues with rear axle sending unit, it never moves the needle and I know it has been over 100 Degrees.)
have plans to add oil temp but haven't yet
Old 07-19-2014, 09:32 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
ideally you have a bung welded to your pan for your sending unit Daniel.mines like yours still...there but not hooked up yet lol!
i was able to use a point and shoot tool to figure out oil temps were the cause of my coolant spikes on the hills.i installed an aux oil cooler and it did the trick.cured what ailed her.i then bought an oil gauge because id like to monitor it,but still need a bung for the pan.
the issue is,you really should (much less dangerous lol) remove the pan from the truck rather than trying to weld on the pan while in the truck still on the engine.
there's really no other "decent enough" place to get your oil temp readings either,than right mid way of the pan.
Old 07-20-2014, 02:07 AM
Several companies sell oil temp senders that replace your drain plug. IDK if there's one that fits but might be worth a look.
Old 07-20-2014, 08:18 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
x2^^^^^^ love mine!
Aeroforce Technology Inc | Products - Interceptor
Old 07-20-2014, 04:26 PM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
Quote:
Originally Posted by oldbird1965 View Post
X3!! I have had an Edge Insight CTS and I really like it. It works pretty well and monitors just about any parameter you will need.
What should my third gauge be monitorig? hobo99 1987 - 1996 F150 & Larger F-Series Trucks 6 11-21-2016 06:36 PM
Anyone know a stock 7.3 normal engine oil temp? USAF CCM 1999 - 2003 7.3L Power Stroke Diesel 54 06-14-2016 08:20 PM
Oil pressure RufusTheGoodTruck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 08-23-2015 08:00 PM
Clutch fan engaging and temp gauge drop tcatrider_99 6.0L Power Stroke Diesel 3 08-26-2014 07:40 AM
Transmission Temp Gauge Questions missouguy 1999 to 2016 Super Duty 19 01-27-2005 02:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
