HELP!!! - Ford Truck Enthusiasts Forums
HELP!!!
Old 07-16-2014, 11:51 PM
mikeycars mikeycars is offline
mikeycars is starting off with a positive reputation.
Unhappy HELP!!!
My 03 6.0 started studdering and lost power going down the road, then died and won't start back. I was told more than likely the irp valve. I bought a socket, pulled the valve to check the screen and there was no screen on it. Ran a magnet in the hole, nothing. No trash, no nothing, no screen. I thought all irp valves had screens. Any ideas????
Old 07-16-2014, 11:56 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
Yes but it does come off. I would get a mirror and get a good look inside the hpop where the ipr mounts and make sure it's not lodged inside. What was your icp while cranking?
Sent from my leash using IB AutoGroup
Old 07-17-2014, 01:27 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Is that screen stainless steel? If it is then the magnet won't
pick it up. having a look back into the hole is a good idea.
Sean
Old 07-17-2014, 09:44 AM
I don't know, don't have a scan gauge or any way of testing. I do have an extendable mirror though, and will try it today. thanks!
Old 07-17-2014, 09:49 AM
Sean
Thanks man, putting a mirror in there today!
Old 07-17-2014, 05:11 PM
Put a mirror in there and still didn't see anything in the hole. Found a piece of the fiber screen housing down in the valley, so decided to tear it down for a better look. May need a new hpop.
Old 07-17-2014, 08:16 PM
78fordman's Avatar
I would but the torque app or scangauge before you start throwing parts at it. If the nylon screen took a crap and then got run through the hpop it could have gotten a small piece of it stuck in the ipr. Take the ipr and press the plunger in by taking a small punch and pressing in from the end. While holding it open flush with some brake cleaner. When you are done you will hear a little bit of air leak through the valve with shop applied through the same end you put the punch in. Then buy a new ipr screen kit and a new hpop screen and put it back together. You need some diagnostic reader to see what is going on.
Old 07-18-2014, 08:51 AM
That's what I'll do, get it back together and buy a scangauge. Thanks man!!!
Old 07-24-2014, 08:22 PM
Scanner
Quote:
Will a CAN OBD11 scanner work on this truck, will it show you values or just codes?
Old 07-24-2014, 09:14 PM
04badford 04badford is offline
04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future
If it will enter the ford Xgauges then yes not all can OBDII readers will work on our trucks , like Actron. they wont even pull DTCs
Old 07-24-2014, 11:39 PM
Quote:
Guess I'll break down and buy a scangauge11!! Thanks for all the info!!!!
Old 07-25-2014, 12:05 AM
Scan Gauges are good when your ready to load the X gauges there's a big list to be seen on FTE, remember there's no sensor for the Fuel pressure, you will have to hook up a gauge for that , some where on here was a code to get the gauge cheaper ,I'll dig around to see if I can find it
Old 07-25-2014, 12:35 AM
Awesome, thanks!!
Old 07-25-2014, 01:03 AM
Old 07-25-2014, 01:08 AM
Robot Check Robot Check
Don't know if the Edge price is good but the function is great.
IRP high flow oil cooler rc.chris 6.0L Power Stroke Diesel 20 09-21-2015 09:06 AM
New issue - hot no start Headviking 6.0L Power Stroke Diesel 21 09-15-2015 05:51 PM
04, 6.0 No Start PMPower 6.0L Power Stroke Diesel 7 07-14-2015 10:04 AM
ICP IRP fishdaddymoe 6.0L Power Stroke Diesel 4 08-30-2014 09:18 PM
HELP!!! mikeycars 1999 to 2016 Super Duty 2 07-16-2014 11:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
