Fuel problems?
Old 07-17-2014, 11:00 PM
fordpride's Avatar
fordpride
fordpride is offline
Originally Posted by lindstromjd
The tach is supposed to move when cranking. If it doesn't, then that's another problem; Cam Position Sensor, or CPS. Motorcraft or IH brand only, NO OTHERS, PERIOD.
I'm going to x2 that you should see what level the fuel tank is showing and if it's anywhere near 1/4 tank, take a 5 gallon tank and put some more fuel into it. Then, see if it will fill up the fuel bowl. If that works, don't ever let the fuel tank get close to 1/4 tank again, unless you feel like dropping it and fixing the fuel pickup, a.k.a. "showerhead".
Not all 97's show tac movement.
Mine didn't and a few others here doesn't.
There is a thread floating around about it.
Old 07-18-2014, 07:21 AM
lindstromjd's Avatar
lindstromjd
lindstromjd is offline
That's a new one to me then. I've always used a no tach movement as a bad CPS diagnosis. But I guess that 97 IS the weird year when it came to different things like a federal and california version...
Old 07-18-2014, 10:26 AM
SOON2BE7.3's Avatar
SOON2BE7.3
SOON2BE7.3 is offline
Hey guys thanks for this great info will be at the truck around 2 and will check all things. How do I determine if my trucks rpm should move when turning over
Old 07-18-2014, 10:38 AM
fordpride's Avatar
fordpride
You can hook it to a scanner to see if it sees rpms climbing or put a cps in it to see if the tac starts moving
Old 07-18-2014, 01:14 PM
SOON2BE7.3's Avatar
SOON2BE7.3
K sounds good bud. Haven't made it to the truck yet but when I do i will check the list you guys have provided me with and touch bases With u guys. Thanks again
Old 07-19-2014, 07:50 AM
SOON2BE7.3's Avatar
SOON2BE7.3
Okay guys I was able to make it to the truck late last night. So I tried checking fuel pressure at the shrader valve but I could not get my gauge on it so did not get to check. But tried cranking the truck over and it did not fill filter bowl up. Also I noticed when I cut key on the wts light came on and cycled but was really fast like 5 sec, it has be around 80 here? So I checked all the fuses under dash and they were good. Then was checking the box under hood and found #17 blown witch was a maxi 30 for the icm or pcm. Replaced it but as I said then I tried again and the batteries for to weak to get it to turn over good. I will be charging battery today and any recommendations on the next step I should to w once I reinstall battery s. Thanks in advance
Old 07-19-2014, 09:35 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Charge the batteries and fill the bowl with fuel. See if it starts. Sounds to me like you need a fuel pump. If the bowl isn't filling up while cranking, more than likely the fuel pump went out. If the WTS light was coming on you still had power to the PCM.
Old 07-19-2014, 11:47 PM
fordpride's Avatar
fordpride
X2^^^^^^
Fuse #22 is for the PCM
Old 07-20-2014, 09:36 AM
SOON2BE7.3's Avatar
SOON2BE7.3
I filled the fuel bowl up with fuel but no start. Will it start even if the pump in wok in? Does that fuel pump on frame pressure rise the bowl or something?
Old 07-20-2014, 10:50 AM
lindstromjd
On a 97, there is only one fuel pump. It's a mechanical pump on the back of the engine right underneath the turbo. It's a dual-purpose; one plunger lifts low pressure fuel from the tank, and the other plunger pushes high pressure fuel to the injectors. The truck will not start if the pump is bad. You need a minimum of about 20 psi to start the truck, and then about 50 to run it. 65-70 psi is ideal.
You also need oil in the HPOP for the injectors to fire. There is a plug on the driver's side of the reservoir at the front of the engine. Oil should be approximately 1/2 to 1 inch below the top of the reservoir.
Old 07-20-2014, 10:54 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
There is no pump on the frame unless some one put in a electric fuel system. From the factory these things came with a mechanical pump on the top of the motor. The pump is a 2 stage pump that first bring low pressure fuel from the tank to the fuel bowl then steps up the pressure to fill the injectors. You need a minimum of about 25psi to make it run. 50+ to run well
Old 07-21-2014, 10:02 AM
SOON2BE7.3's Avatar
SOON2BE7.3
01 since at shrader valve with a no start and does not fill up bowl? Is it safe to mechanical fuel pump? Thanks guys
  #28
Old 07-21-2014, 11:16 AM
fordpride's Avatar
fordpride
How much fuel is in the tanks ?
Have yiu tried both tanks ?
  #29
Old 07-21-2014, 08:49 PM
SOON2BE7.3's Avatar
SOON2BE7.3
Yes, there is a full tank on the rear which the truck was running on when it shut down and the front tank is a little over half. Tried both tanks and still the same with 0psi at shrader valve while cranking over. Thanks for coaching me along.
Elmo154
08-16-2015 09:55 AM
trevorrules
18
08-27-2014 09:56 PM
savering
Modular V10 (6.8l)
08-23-2012 09:25 AM
drewinator
63
01-16-2012 02:50 PM
mark460
18
08-30-2011 06:32 AM
Quick Reply: Fuel problems?
