Newfound Hub compatability! - Ford Truck Enthusiasts Forums
Old 07-16-2014, 09:35 PM
Mtphammer's Avatar
Mtphammer Mtphammer is online now
Mtphammer has a very good reputation on FTE.Mtphammer has a very good reputation on FTE.Mtphammer has a very good reputation on FTE.Mtphammer has a very good reputation on FTE.
I've got a '53 f250 that I've been workin on and of course the p.o. Had converted it 5 lug because he wanted it to be a hot rod. So now I've been looking for hubs to get back to eight lug. Yesterday I realized before I got out and buy hubs, maybe I should try using some that I already had. That leads me to my other truck, a 1948 f3. Long story short, the hubs from a 1948 f3 fit the spindles of 1953 f250. That's right folks they fit with no play, wobble or any movement in the wrong directions.
Old 07-17-2014, 10:07 AM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
Good to know but what about the backing plate, etc? So you want to go back to the F250 drums on the front? Just curious why. On my F250's I wanted to get away from the 8 lug and drums that always locked up.
Old 07-17-2014, 10:27 AM
Jules The Great Jules The Great is offline
Jules The Great is gaining momentum as a positive member of FTE.Jules The Great is gaining momentum as a positive member of FTE.
Could do a disk brake conversion. Some people have modified the 78 Era Ford mounting brackets to work.
Old 07-17-2014, 11:27 AM
teardropty's Avatar
Quote:
It sounds like that is what was done already. I do a disc conversion on all my F250/350 to get rid of the 8 lug and give me a better selection of wheels and better braking. The only reason, IMHO, to keep the 8 lug is for weight capacity or conservation of a stock truck.
Old 07-17-2014, 11:43 AM
I went from 5 back to 8 on my F250 and did a disc brake conversion at the same time
Old 07-17-2014, 11:47 AM
teardropty's Avatar
I would welcome a detailed write up on what was used and what mods had to be done. Thanks.
Old 07-17-2014, 05:54 PM
blue_cloud blue_cloud is offline
blue_cloud is starting off with a positive reputation.
Quote:
Yes me too! and photos!
Old 07-17-2014, 06:15 PM
Mtphammer's Avatar
The reason why I'm converting to eight lug is because of bigger discs and better load capability. There is a commercial kit available to convert 48-52 8 lug and 53-56 8 lug to disc brakes. There is also a write up on this forum that instructs u step by step on how to install the kit.
Old 07-17-2014, 06:18 PM
That kit uses Chevy rotors and calipers. ... in case you care another that stuff.
Old 07-17-2014, 06:24 PM
Mtphammer's Avatar
Yup that's the one. Plan on purchasing it once I get the hubs squared away. I know I said the hubs fit, but I decided against using them for my application simply because of the weight I will be hauling at times. That means I will be heading to the local trailer supply store and purchasing a pair of Hubs soon. I know they'll have the right size because most trailer axles and accessories are made to ford's specs.
Old 07-19-2014, 05:46 PM
Here is what I did.
http://www.ford-trucks.com/forums/13...sc-brakes.html
Let us know if you can find anything, but I am using the original hubs and I would think they are plenty strong.
1948 flathead vs. 1948 flathead kens65fb 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 08-17-2016 03:33 PM
1966 Front wheel hubs NDChris 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-31-2015 04:15 PM
Wheel Hub Measurements oldracerjones 1961 - 1966 F-100 & Larger F-Series Trucks 3 02-01-2015 08:39 PM
Budd Wheels 17.5" tubeless jmadsen Ford Truck Parts for Sale 14 01-25-2015 04:42 PM
Front spindle conversion? Butchashop 1967 - 1972 F-100 & Larger F-Series Trucks 0 08-04-2014 10:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
