big door gaps
on
The hinges are all-way adjustable. On some trucks you can never even everything out. I usually line up the area where the "dent" and cowl are first then get the bottom edge close and the top just ends up wherever.
Never seen a bent hinge. They don't bend.
As pa f250 said, adjust the hinges with the latch striker off. Install the striker when the door is perfectly lined up.
Just have to be patient and take your time, yes lots of loosen/smidge/tight/check-repeat.
X2 on getting the main body "dent" lines to line up. And X2 on the hinges do not bend down, yes the bushings get worn out and they can get sprung from being opened to far and the area on the door where the hinge mounts will be bent, but I have never seen a hinge bent down.
Door hinge 101: You could look at the hinges on the driver side compare them to the passenger side. You will see that there is only two hinges and they are upside down on one side of the truck, ford only made 2 hinges for the 4 locations, so take the hinge you need from the opposite side off a truck in the wrecking yard as the passenger sides get used way less.
So lower driver side hinge matches upper passenger side - they are the same part
And upper driver side hinge matches lower passenger side - they are the same part
Also before you ever remove a door for body work, paint ect. Especially if you are using the same door and hinge, scribe mark where the hinge is positioned that way is will be easy to line back up. And if you can, at least leave the hinge on the truck or the door.
Closing up those gaps between top o fender and cowl is tough. The bottom of the fender basically has no upward adjustment. The rad support up/down can help a bit with the fender to door gap tapering from top to bottom. Because the fender bolts right to the rad support, those slots in the fender top really don't do much and you have to basically push or pull the whole front clip (inner fenders, rad, and fenders) at the inner fender support brackets to open or close the fender to door gap.
It helped me to think carefully about each step instead of just loosening things and moving them around. Not everything moves like you would think it might and most times an improvement in one area tweeks something in another.
Remember the cowl is fixed and fenders have to be adjusted to get that gap correct. Once that's done, then the front edge door gap, and like stated before, go for a good "dent "line up on each side.
Then the hood will be outa wack, make sure your hood hinges are not sprung or bent, and you have the rubber bumpers on the hood.
Core support is mounted to the frame with rubber bushings and can be a PITA to get apart. There is really no height adjustments, as far as I know.
Ck the cab mount bushings, them being dry rotted or god forbid you have rusty/weak front cab mounts and then the front of the cab settles, you can be chasing your tail on gaps.
there are round disc spacers to use to lift up the core support, the core support bolt goes right through them, they have been on many trucks Ive pulled apart. the thickness of the bushing is set though, you can adjust up, kinda impossible to lower the bushing-and I'd say if you have to lower it that something else is waaaay out of whack elsewhere with frame or cab
