a few questions
a few questions
Hello Guys,
i just recently purchased a 2003 F-150 SuperCrew 4x4, 5.4L, 3.73LS rear.
my questions are:
what brand/type of transfer case does it have/use?
why did it come with the 3.73 rear-end, since i've noticed in this forum that most of the '02s came with the 3.55?
what brand/type and gear ratios are in the front axle?
can the bed extender be taken out without opening the tailgate?
thanks for any answers you might help me with guys.
robert
my questions are:
robert
a few questions
What ever gear ratio that is in the rear is also in the front. The front axle should be an 8.8" and the rear is probably a 9.75".
As far as the ratio, It is just how the truck was ordered by the dealer. I kinda wish I had the 3.73 instead of 3.55's but they will do fine. If you tow anything , the 3.73 will give you better acceleration. The gas mileage difference will be minimal.
Jimmy
Jimmy
a few questions
As for the higher gear ratio........usually vehicles with standard transmissions are geared lower (numerically higher).....are you sure that your comparison is based on vehicles with the same tranny?
hey Jeremy... i do know that mine came with the 3.73 LS, however, the comparison i'm making is looking at most of the sig lines that show 2000-2002's with 3.55's. as far as same trannies, i guess you're right, i am assuming that most are automatics...since i don't think you can get a manual on the 5.4 and 4.6's, only on the 4.2...right?
a few questions
The bed extender if properly installed cannot be removed with the tailgate closed. Make sure when you install you install it with tail gate open and the extendender in the open position. Then Flip it over and close and lock the tailgate then you will not be able to get it off without opening the tailgate. If installed the other way it comes out very easily for fast removal for anyone who wants it.
a few questions
