Ac blows hot but defrost blows cold - Ford Truck Enthusiasts Forums
Old 07-16-2014, 08:43 PM
velocicurtis velocicurtis is offline
velocicurtis is starting off with a positive reputation.
My AC blows hot air, like heater hot, but the defrost on cold blows cold air. At first the AC would cut out at low rpm's (stop sign or red light) and cut back on, now its nothing. But the defrost blowing cold, enough to fog up the windshield, tells me its not the compressor or freon. Any ideas?
Old 07-16-2014, 11:07 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Sounds like a blend door problem, which would include a problem in the head unit. It could be opening the door to the heater core in the dash register position. Can you use the temperature **** to make the defroster air warm?
Old 07-17-2014, 11:39 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
blend door is controlled by electric motor and adjustable from cold to hot. It mixes the air to get correct temp. Common for door, control arm, or gear box to strip out. location is under the radio, above the transmission hump. Remove plastic panels for access.
2005 Exp not blowing air NottiAlaska 1997-2006 Expedition & Navigator 4 10-07-2016 06:31 AM
1996 F250 AC blowing cold...out of defrost only JoeM1965 1987 - 1996 F150 & Larger F-Series Trucks 7 09-03-2016 11:12 PM
1999 Ford Explorer Blowing cold air ashlatz Explorer, Sport Trac, Mountaineer & Aviator 12 10-03-2014 07:57 AM
Heater control stuck.....? OAS 1999 - 2003 7.3L Power Stroke Diesel 5 06-03-2014 10:36 PM
Nothing but Hot even on A/C hhoelsc Cooling, Heating, Ventilation & A/C 6 04-15-2004 11:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
