99 f150 removing bed bolt question - Ford Truck Enthusiasts Forums
Paint & Bodywork SPONSORED BY:
Old 07-16-2014, 08:01 PM
pancake's Avatar
pancake pancake is offline
pancake is starting off with a positive reputation.
i have a heavily rusted 99 f150 thanks to good ole new york state road salt with a bed that is beyond repair...
i came across a halfway decent replacement bed...got it and i plan to swap it this weekend in addition to some other work on the truck...
from all the reading that i have done...everyone says you have a better chance of seeing the real live easter bunny than you have of getting the junk TORX bolts out without issue...everyone says cout the heads off the old bolts and replace them with new ones.....i attempted to turn one of the old bolts just to see if by chance mine would turn out and the about 2"of the bolt snapped right off including the head ...well that is one less i have to cut...
MY QUESTION>> once the top of the bolt is removed by way of cutting or breaking ......how does one go about removing the remaining part of the bolt that goes through some silly clip and the mount on the frame??
is more creative cutting required??
Old 07-18-2014, 08:29 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
If I were doing this on a junk bed I'd simply drill out the head using a powerful enough corded drill motor. Much like drilling the head off a pop rivet, afterwards you could just lift the old bed right off.
Once off removing the rusted-in-place remaining bolt portions should be fairly easy with all that access.
Not sure on your year if the bed bolts are held to the frame with a clip like you say or some other female threaded part, no doubt almost unobtainable from Ford or anyone else---that'd be my luck anyway.
IF its just a folded nut or U-Clip those can be matched to a new bolt's thread pretty easily, AuVeCo through Clipsandfasteners.com would be my beginning place when searching.
HTH
Old 10-03-2014, 09:58 AM
bublitz3's Avatar
bublitz3 bublitz3 is offline
bublitz3 is starting off with a positive reputation.
Once you break them, or grind them go to the next and remove all of them once the bed is removed I think its a simple clip holding them in and you can just pull them off. I did this on my 8 foot box super duty it wasn't too bad. A little FYI start looking for those replacement bolts and do not buy from the dealership last time I checked they wanted $150.00 for 1!!!!
Old 08-01-2015, 05:50 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
rockauto has dorman kit. $38 for 6, $49 for 8
Ford truck bed bolt lengths Nick-koziol 1999 to 2016 Super Duty 3 07-29-2016 09:22 PM
V/Modified B codes, step-by-step robert_l_ross Excursion - King of SUVs 233 04-21-2016 09:16 AM
Exhaust Manifold Leak/Headers + Full Exhaust JLuskin 1987 - 1996 F150 & Larger F-Series Trucks 10 08-26-2015 01:18 PM
A/C compressor question 1980Supercab 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-14-2014 09:38 AM
York to Sanden Conversion mikeo0o0o0 1973 - 1979 F-100 & Larger F-Series Trucks 22 06-28-2013 03:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
