Newbie question: 6 volt vs. 12 volt system - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 07-20-2014, 09:20 AM
fordf348's Avatar
fordf348 fordf348 is online now
fordf348 is starting off with a positive reputation.
I like my generator....how do I polarize it?
  #62
Old 07-20-2014, 09:31 AM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Quote:
With the engine off, at the regulator, remove the field (F) wire and briefly touch it to the batt (B) connection. You should see a small bluish spark. Re-connect the field wire and you're done.
  #63
Old 07-20-2014, 09:46 AM
fordf348's Avatar
OK, polarized it, swapped wires, started engine, gauges still working properly.
Thanks for the help Shane
Heading out with the truck for a ride below the Mason/Dixon line
  #64
Old 07-20-2014, 09:49 AM
Jacnat's Avatar
Jacnat Jacnat is offline
Jacnat is starting off with a positive reputation.
Walk me through what you just did when you have a minute please. What is involved in polarizing?
  #65
Old 07-20-2014, 09:51 AM
Doc's Avatar
Doc Doc is offline
Quote:
I posted it above in post #62.
  #66
Old 07-20-2014, 09:52 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Here's a short video on polarizing the generator...
  #67
Old 07-20-2014, 09:53 AM
fordf348's Avatar
jacnat, just do what Doc suggests in the post before mine.....permalink 62....takes 10 minutes to find the screwdriver and 1 minute to do the job
  #68
Old 07-20-2014, 03:20 PM
petemcl's Avatar
petemcl petemcl is online now
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Voltage meter jumps around a lot but when I rev slightly it moves to charging. I can borrow a 6 volt this weekend and try that. As someone earlier said, I don't think I can trust that PO properly installed this new battery.
Shouldn't that be an ammeter? Unless someone changed the gauges. The back of the gauge has no connections (see picture) rather it picks up on the magnetic field created when the circuit is on. The front of the gauge should say battery. with charge and discharge markings.
What do the rest of the gauges do when the engine is running?
  #69
Old 07-20-2014, 03:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
OP really needs to pull off the coil, voltage regulator, and wiper motor, to determine if there are any voltage markings on them.
There's no ballast resistor, no gauge voltage reducer, just the one 12v light bulb and a 12v battery thrown in to get it sold. I think this is a 6v truck with 2 incorrect parts.
If a 12v truck is desired in the end, then a step-by-step conversion should be done AFTER replacing the bad wiring.
1950 ford truck 6 volt or 12 volts beckman 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-14-2016 02:43 PM
No Crank No Start NEED help ASAP armyveyf250 6.0L Power Stroke Diesel 19 07-26-2016 01:51 PM
voltage regulator bad or generator? jhaas63 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-15-2013 01:01 AM
Alternator bypass fixes airharley 1961 - 1966 F-100 & Larger F-Series Trucks 0 04-15-2011 07:05 PM
Charging Problems - 1989 F-150 varunner696 1987 - 1996 F150 & Larger F-Series Trucks 16 07-10-2009 06:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
