6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
5R110 or turbo noise
Old 07-16-2014, 05:11 PM
Chuck Druce's Avatar
Chuck Druce
Chuck Druce is offline
I have a really bad noise coming from the rear of engine under dash. sounds like cavitating or cratered bearing. it only occurs when pulling fifth wheel, 55 ish MPH 3000 ish RPM (that is hard pulling uphill) not sure of the gear it is in. letting off will stop the noise. is this a shift point problem? do the turbos produce this kind of noise? also have a shudder when taking off from stop lasts until I am over five-8 mph. and when slowing to stop there is a very hard downshift. 08 350 SD 6.4 PS. any suggestions?
Old 07-17-2014, 05:04 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
Every have the tranny serviced? How many miles?
When towing you are in tow/haul mode? If so then that explains the downshift.
the shudder at take off has to do with the driveline angle when loaded. Very common problem till you get moving.
Old 07-17-2014, 09:33 AM
Chuck Druce
I have 78000 on truck, purchased with 48000 miles, I was told it had a "full service" oils and fluids, had both filters and 9 quarts replaced at about 60000. the shudder and noise are only noticed when towing 16k fifth wheel, the hard downshift is about 90% of the time loaded or not. and if drive line angle when loaded is common is there a common solution.
Old 07-17-2014, 09:39 AM
senix's Avatar
senix
senix is online now
air bags to raise the rear back up when loaded works well.
Now about the turbo noise. Could that better be described as the blend door actuators?
Try shutting off the HVAC and see if the noise goes away.
Old 07-17-2014, 10:18 AM
Chuck Druce
not a/c related happens irrespective of ac or fan settings the sound is loud and sounds like a cavitating prop with some gravel thrown in for good measure. could fluid be shearing or boiling off in valve body of tranny. seems that if it was turbo it would severely damaged, and noisy all the time.
Old 07-17-2014, 10:26 AM
Chuck Druce
found another thread on shudder and tech sheet for for shimming the carrier bearing. since everything sits level when loaded, i will look into this.
Old 07-17-2014, 10:27 AM
senix's Avatar
senix
senix is online now
Don't think so..perhaps you could do a video so we can listen?
Old 07-17-2014, 10:36 AM
ncalf150's Avatar
ncalf150
ncalf150 is offline
I just read all. Senix is right, why not do a video and share here. Readers will have a better idea of what is going on.
Old 07-17-2014, 11:55 AM
Chuck Druce
my build date is 4/07
Technical Service Bulletins
TSB Main Page :: Year 2007 :: Model F-250 :: TSB 06-23-4
TSB
06-23-4
DRIVE-AWAY SHUDDER OR VIBRATION
Publication Date: November 3, 2006
FORD:
1999-2007 F-Super Duty
This article supersedes TSB 05-17-6 to update the vehicle model years.
ISSUE:
Some 1999-2007 F-Super Duty vehicles may exhibit excessive drive-away shudder or vibration, under moderate to heavy acceleration from a stop. This may be due to driveline angle.
ACTION:
Shim the center carrier bracket downward to correct the condition. Refer to the following Service Procedure.
SERVICE PROCEDURE
When shimming the center carrier bracket, a maximum of three (3) 1/4″ shims may be used (EOTZ-4A209-A). When refastening the carrier bracket use bolt (56564-S2). A 7/16 x 14 grade 5 bolt may be substituted providing that it extends at least three (3) threads past the nut. Use Motorcraft® Threadlock 262, and torque bolts to 46 lb-ft (62 N-m).
NOTE: IF THE VEHICLE IS NORMALLY LOADED, ROAD TESTS WILL NEED TO BE PERFORMED WITH THE VEHICLE LOADED.
Before beginning the repair, road test the vehicle to gain a feel for the harshness of the shudder/vibration.
Install one (1) shim, (DO NOT use threadlock on the bolts at this point), re-road test vehicle.
If condition is corrected, apply threadlock and torque bolts as directed above.
If condition is not corrected, re-perform step 2 (to a maximum of three (3) shims) and reevaluate vehicle.
NOTE: IF THE CONDITION IS STILL NOT CORRECTED AFTER INSTALLING A MAXIMUM OF THREE (3) SHIMS, REFER TO WORKSHOP MANUAL SECTION 205-00 FOR FURTHER DIAGNOSTICS.
PART NUMBER PART NAME
EOTZ-4A209-A Shim
56564-S2 Bolt
TA-26 Motorcraft® Threadlock 262
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
062304A 1999-2007 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair (Includes Time To Raise Vehicle And Install Threadlock) (Do Not Use With 4602A, 4602A4F) 1.2 Hrs.
062304B 1999-2007 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair Condition Still Exists, Install A Second Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock) (Do Not Use With 4602A, 4602A4F) 1.7 Hrs.
062304C 1999-2007 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair Condition Still Exists, Install A Second Shim And Road Test Condition Still Exists Install A Third Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock) (Do Not Use With 4602A, 4602A4F) 2.2 Hrs.
__________________
Old 07-19-2014, 01:11 AM
Chuck Druce
OK couldnt upload video here but put it on facebook https://www.facebook.com/photo.php?v...type=2&theater
the noise isn't as loud as when loaded, just mutiply by a factor of 10.
whats the red line for the 6.4?
Old 07-19-2014, 07:09 AM
senix's Avatar
senix
senix is online now
I Believe if you were going uphill that you were in 3rd gear. RPM's look like it based upon the speed.
Redline is controlled by the PCM but I would not exceed 3500-3700 rpms. Running in towhaul and hard pulling up a hill if the tranny downshifts you will be fine. It won't exceed the redline.
that noise almost sounds to me like either you have a leak on one of the boots or you are bleeding off excess boost.
Looking at your turbo guage you are not pushing that much boost so maybe the boots should be looked at.
That is what I think is going on. Hope Tom listens and gives his thoughts, but check the boots.
Old 07-19-2014, 12:27 PM
Chuck Druce
my video was with the truck unloaded i had to go into second with tow/haul on to recreate the noise, When i am hauling and going uphill losing speed down to about 60 and it shifts down into what i think is second, and I have the torque to regain speed, but the sounds are not good and i must let off and stay at 50. I checked the boots,... entire induction system. didn't find any thing that looked off, no chafing, no cracks, bands are tight, no hot spots, no obvious oil leaks,(might be a spill on top of engine and boots have collected dust), linkages to turbo feel tight and move freely. heat shields are are in great condition and fully fastened, might have a left engine mount that is showing some signs of wear. fluid is bright and no odor, full.
Last edited by Chuck Druce; 07-29-2014 at 12:09 PM. Reason: oops! third gear not second
Old 07-24-2014, 06:44 PM
Softballdad's Avatar
Softballdad
Softballdad is offline
We're you able to figure out what the noise was? Mine started making the same noise bringing my RV home this weekend. Checked under the hood and everything is tight, so not sure what it could be.
Old 07-24-2014, 06:49 PM
senix's Avatar
senix
senix is online now
I have no idea other than what I mentioned earlier as a possibility.
Old 07-24-2014, 08:07 PM
Softballdad
Gonna hook up the RV this weekend and try to diagnose. Let you know if I figure anything out.
Quick Reply: 5R110 or turbo noise
