Weekend incident with Ol' Red - Ford Truck Enthusiasts Forums
Old 07-16-2014, 03:01 PM
wallster's Avatar
wallster wallster is offline
wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.
Stopped by my friends shop to change my leaky pinion seal on Saturday morning and on the way home noticed the steering started to pull hard to the right. It became even harder as I was driving so I pulled into the next parking lot to check it out. Turns out I had a right front tire go flat. The building next door from where I was located was a Goodyear so I drove it to their front door. The tire was chewed up enough to warrant a new one so I ended up buying two that were one size narrower than what I had (the right front was too close to the fender lip for comfort and since the previous tires were free I didn't feel so bad buying two new ones). When the mechanic/tire dude drove my Ol' Red around back he told me that it was leaking transmission fluid. When I took a look at it, it was the rack that was spewing the fluid. It turns out (no pun intended) that when I was cranking on the wheel to steer it into the parking lot the rack loosened up enough to pull on a line which made the fitting on the rack leak. I tried to re-tighten the fitting but it still leaks. Next stop, my other friends shop who has a lift so I can replace the o-ring on the fitting and get the rack dry again. To think how happy I was when the pinion seal replacement went so well.
I've got to admit though that I've been thrilled so far with how the truck is running and working, I love driving this truck. We even picked up six 80lb. bags of concrete and two pressure treated pieces of lumber last week.
Wally
Old 07-16-2014, 07:33 PM
bobbytnm's Avatar
bobbytnm bobbytnm is online now
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Wally,
Its always something......LOL
Sometimes owning an old Ford is like stepping on your own *****.
I'm glad you got the pinion leak fixed. Good luck on the other little things. Its great that you are out there driving it and working out the bugs. Its a beautiful truck
Bobby
1998 Ranger steering issues Buckwacka Ranger & B-Series 1 10-22-2014 11:10 PM
Edge Power Steering Fluid Loss mpwbw Crossovers 0 07-13-2014 12:00 AM
2000 Excursion highspeed rotational roar - out of ideas sammie0126 Excursion - King of SUVs 28 09-11-2012 10:16 PM
Power steering fluid vs. ATF geearturi Aerostar 9 01-21-2012 05:53 PM
How a new tire purchase can go bad... (long) Spike Engineering 1999 to 2016 Super Duty 83 12-22-2010 12:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
