P0284 - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
P0284
Old 07-16-2014, 03:37 AM
Diesel Submariner's Avatar
Diesel Submariner Diesel Submariner is offline
Diesel Submariner is gaining momentum as a positive member of FTE.
P0284
G'day Fellas,
Ran a few tests on the Henry today (AE from Clay).
Dead cold and did the KOEO and all good (Buzz test, sensors etc).
Checked for codes and only had P1211 and that would be the PHP FU2 6 Pos Chip. Also the soft code that throws due to AIH Delete mod (can't think of the number off top of head P03--).
Cleared the codes and P1211 didn't reappear for the rest of the tests.
I left the Chip in during tests but had it set at the lowest (Extra 25HP being closest to stock).
Took her for a good run to get up to full operating temps and ran a KOER test and all good.
All data looked good ICP, pulse widths etc.
Ran a Cylinder Contribution Test and came up with:
P0284 Cylinder 8 injector circuit contribution/Balance fault
The truck is running beautifully with no sign of a miss, smoke etc.
I know that the Gray CPS can throw this as a Phantom Code.
Just wondering if any of you fellas get the same code on our Aussie 7.3 trucks?
Cheers,
Reg
Old 07-18-2014, 06:39 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Reg, I'll check my DTC log and let you know.
I'd be inclined to clear the codes, use the truck normally, and check for a re-appearance before you worry too much about it.
Old 07-25-2014, 04:35 AM
P0284
G'day Simon,
Done that mate as a matter of course.
However it comes up again after retesting.
Still let me know if and when you throw the AE over yours again.
Cheers,
Reg
Old 07-25-2014, 11:06 AM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Old 07-26-2014, 09:06 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
agreed. dont worry about #8. it has a different stroke than the others. Fords lame *** way of trying to fix the fuel starvation on that cylinder. The only real fix is to install a regulated return.
Old 08-07-2014, 05:47 PM
Blue7.3's Avatar
Blue7.3 Blue7.3 is online now
Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.
I fitted Clay's FRx and that seem to settle the noisy number 8 down some and also fitted the HPx as well , some say this will give you a smoother idle but that's debatable.
I run AE last week and pulled some codes
B1428
B1483
B1352
which are no weal problem as for the AIH delete , i still get a soft code but no biggie , i made up a wire with some resistors in line to stop the soft code , will check it out and let you know.
P0269 Cylinder 4/P0284 Cylinder 8 running a little rough mrm8174 1999 - 2003 7.3L Power Stroke Diesel 9 03-07-2016 04:12 PM
Cylinder 8 contribution fault BRay09 1999 - 2003 7.3L Power Stroke Diesel 11 07-24-2014 11:33 AM
Surging & rough idle mrjimbov 1999 - 2003 7.3L Power Stroke Diesel 8 02-15-2014 08:07 PM
2004 Excursion P0284 / P0488 Misfire dletourneau3 6.0L Power Stroke Diesel 7 01-15-2014 10:54 PM
Pandora's Box Delvac1 1999 - 2003 7.3L Power Stroke Diesel 11 10-09-2008 11:42 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
