fender mounting - Ford Truck Enthusiasts Forums
fender mounting
Old 07-15-2014, 10:24 PM
crewchief99 crewchief99 is offline
crewchief99 is starting off with a positive reputation.
fender mounting
how do i know if my cab is on the frame straight? I am trying to fit my fenders on but i wanna make sure my cab is straight on the frame.
Old 07-15-2014, 11:53 PM
my 66 my 66 is online now
my 66 is starting off with a positive reputation.
straight
Quote:
First, is the frame square, then you can measure from factory hole to body on both sides. That would put it straight on the frame. Then put the radiator support on then the inner fenders. If every thing goes on with no problems the fenders and hood can go on. There is some slack in the bolt holes were things can be pushed and pulled to help line every thing up. Good luck, it just take a little adjusting to get everything looking good.
Old 07-16-2014, 02:17 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
what year are you putting the fenders on?
Old 07-20-2014, 03:07 PM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Suggest that you use the USERCP link in the top left to edit your location details and to add your year and model to your signature.
Rumor Check: Does the cab sit higher on the drivers' side? wavetrain75 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-15-2017 04:02 PM
57 f700 project 79F150/F600 1957 - 1960 F100 & Larger F-Series Trucks 25 01-20-2016 11:35 AM
1978 Ford F150 Knubbler Ford Truck Parts for Sale 8 03-27-2015 06:01 AM
'52 inner fender bolts to cab 49fordv8f4 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 10-27-2014 02:27 PM
inner fender structural questions bobbytnm 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 02-13-2009 08:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
