Floor or column headlight dimmer? - Ford Truck Enthusiasts Forums
View Poll Results: Floor or column dimmer?
Floor 18 58.06%
Column 13 41.94%
Voters: 31. You may not vote on this poll
Old 07-15-2014, 08:23 PM
damarble damarble is offline
damarble is gaining momentum as a positive member of FTE.damarble is gaining momentum as a positive member of FTE.
I posted on FB about a mod I was doing to get my dimmer switch off the floor and was shocked by how many people said I was nuts to do it. What does this forum think, is the floor or the column a better spot?
Old 07-15-2014, 08:29 PM
flyhound flyhound is offline
flyhound is starting off with a positive reputation.
Floor! Keeps both hand on wheel. Easy part to replace if needed. Plus when I hit my dimmer on other vehicles half the time I also turn the turn signal on or turn my wipers on when I don't want to.
Old 07-15-2014, 08:30 PM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
I prefer column, but not the ones that move the turn signal switch where it stays in a different position depending on beam choice. My favorites are the ones that are a click pulling the turn signal switch back.
I dislike floor ones, to many other things for your feet to do(clutch), too easy to hit it unintentionally, and harder to flash quickly.
Old 07-15-2014, 08:49 PM
SteelHorse4x4's Avatar
SteelHorse4x4 SteelHorse4x4 is online now
SteelHorse4x4 is starting off with a positive reputation.
Yea, convenience is nice, but the floor dimmer just has some nostalgia that the newer tucks lose when its all about comfort. I vote keep the floor.
Old 07-15-2014, 08:52 PM
Quote:
By that logic we shouldn't modify our trucks at all on anything.
Old 07-15-2014, 08:56 PM
Here is my problem with the floor dimmer.
Often corroded from snow and mud getting tracked in.
Floor mat wedges underneath stopping it from clicking.
Running down the highway with cruise on I don't want to have to move my foot for every car.
Can be hard to feel with heavy boots.
Unnatural compared to modern cars (a lot of us have a newer DD we switch back and forth to).
Old 07-15-2014, 08:57 PM
I agree with all of that,
Old 07-15-2014, 09:26 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
the only thing i didn't like about the dimmer on the floor was while shifting and if you met a car,you had to slide it into neutral quick,let off the clutch and swing your foot over to hit the dimmer so you didn't blind the guy for too long and then find a half decent gear to get rolling again.hopefully another car didn't come if you switched back to high beams while your still picking up speed lol.good memories.
if she was an auto,id go with the floor.but all cars and trucks have moved from those a long time ago of course,so if you've got a small car you run too,you might find yourself ghost dimming on the floor lol.
Old 07-15-2014, 09:33 PM
Yea, let's just get rid of all the things that made some of these old girls special to us at some point or another, like wing/vent windows, and floor vents. Oh ****, they already did that. I didn't say that the comforts and advances weren't for the better, just that some of those old features and quirks hold a nostalgia that the new, quiet, plush trucks just can't provide, period.
Ghost Dimming. God its been sooooo long since I did that, but as soon as you said it, LOL
Old 07-15-2014, 09:44 PM
I'll bite, what's ghost dimming?
Old 07-15-2014, 09:59 PM
obviously someone who's never dealt with the transition between floor and column dimmers, and until you experience it, all you'll do is throw around semi-bashing, put-down comments until then.
Old 07-15-2014, 10:02 PM
Huh? You make no since?
Semi-bashing? I'm a truck driver.
Old 07-15-2014, 10:09 PM
WOW, ok. For the ones who have never experienced it when your DD had the floor dimmer, and you were driving a newer column dimmer, you kept tapping your foot to dim the lights, and would sometimes do it 3 or 4 times trying to find that dam dimmer, thinking it got buried under the floor mat AGAIN, until you remembered it was on the column and you felt like a dumb azz. LOL
Old 07-15-2014, 10:12 PM
OK, I do that on my way home in my personal truck(auto) after leaving my work truck looking for the clutch pedal and shifter. I guess you'd say I ghost clutch.
Old 07-15-2014, 10:17 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Agreed with all the above and when shifting it gets to be a pain.
if it was on the floor, I would leave it. I would NOT move it
Dimmer/illumination wire? ngng 6.7L Power Stroke Diesel 5 02-17-2015 05:04 PM
highbeam dimmer switch relocation stang_me1990 1973 - 1979 F-100 & Larger F-Series Trucks 21 06-19-2012 11:27 PM
Dash Lights on 2001 F150 joannev 1997 - 2003 F150 3 02-11-2009 11:51 AM
Why not dimmer on floor anymore? Gray Wolf General Automotive Discussion 26 03-24-2005 11:25 PM
Floor dimmer switch Black Ford XLT 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 03-02-2005 01:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
