Rear Glass Wiring Issues
Howdy gents
I recently acquired a 1989 Bronco XLT. The poor thing has wiring issues. It runs and drives, but it needs some TLC before I DD. First issue I wanna solve is the dang gone rear window. They messed with the wiring nad it will not roll up nor down. Now i know the safety switch thingy is known to go bad and cause problems, and I was going to by pass it anyway, but the problem I have ran into is I can not find a wiring diagram, with color codes so I can wire this thing up and see if the motor works. So could someone be kind enough to post some diagrams? I have googled and I get a crap ton of vacuum diagrams and other wiring diagrams but none for the rear window. All help is appreciated.
Thanks in advance!
Thanks in advance!
http://www3.bc.sympatico.ca/cbradley...wschematic.JPG
I couldn't get it to post the pic so hope this works for you. the safety switch is kinda a pain in the @$$ (if you like me, have giant hands) but its easy to just unplug pull it so you can get some wire or blade terminals in there and jumper it and see if the window goes anywhere.
RMBC Freeride
11-30-2020 08:41 AM
