mustang II shocks - Ford Truck Enthusiasts Forums
mustang II shocks
Old 07-15-2014, 05:22 PM
Tushy Tushy is offline
Tushy is starting off with a positive reputation.
mustang II shocks
hello everyone,what length you guys recommend of the shocks,factory 32118 or longer?I think I have heidts ifs.cheers
Old 07-15-2014, 08:45 PM
tomrflorida tomrflorida is offline
tomrflorida is starting off with a positive reputation.
SHOCKS
I have the same Heits set up on my 49 F1 the shocks do not want to go in to the bottom mount and then they are about 1/2" to short to get the nut started. I spent hours going over the Monroe mounting & length sheet
http://www.monroe.com/retail/assets/...engthSheet.pdf
The only shock that has close to the same mounts is # 5815 The top mount( S-4) is the same the lower mount is 3/16" shorter (LS19) ( 32118 use LS20)
on the 5815 comp is 8.75" ext is 13.25" travel is 4.50"
on the 32118 comp is 8.375" ext is 11.00" travel is 2.625"
Old 07-16-2014, 02:24 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Easy solution is NOT to buy cheap crap Monroes! Shocks are the most important part of the suspension and valving should be matched to the spring rate and vehicle axle weight. Monroes and the other mass market shocks all use the same junk internals no matter what the application.
Old 07-18-2014, 05:31 PM
How far along are you do you have the brake lines done yet? If you do can you tell me what hoses you used & maybe post some pics. I have been trying for weeks to get this done
Old 08-23-2014, 09:23 PM
jonf jonf is offline
jonf is starting off with a positive reputation.
OK, so all Monroe shock are crap?
Quote:
So, AX, give us a recommendation?
Old 08-23-2014, 10:24 PM
wallster's Avatar
wallster wallster is offline
wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.
I replaced the no-name shocks on my '51 (with a helix IFS kit... heidts is much better) with a set of monroe 32118 shocks (bought them from Summit) and they fit and work great.
Wally
Old 08-24-2014, 12:58 PM
AXracer's Avatar
Quote:
I've done this several times before, but once again the shock manufacturers I'd recommend that offer shocks valved for the application (all have customer support experts that are glad to help with selection, they want their customers to be happy with their shocks and to have them work properly. Just be sure you are talking to the manufacturer, not just a distributor or rebuilder.) All (except Bilstein) offer non adjustable, single adjustable and double adjustable models. I'd suggest using non adjustable for low speed around town driving, single adjustable if you like performance driving, tailored feel, occasional corner carving, and double adjustable for maximum performance with an updated front and rear suspension, and occasional drag racing.
In no particular order my recommendation would be: Koni, Bilstein, Penske, Afco, QA1, KYB. There are a couple others I may have skipped. In shopping for adjustable shocks be sure the adjustment(s) affects only the rebound (most single adjustable) or rebound and compression (double adjustable) separately.
There are a couple manufacturers (aimed primarily at the tuner/poser/stance crowd) where the single adjuster supposedly adjusts the rebound and compression simultaneously. NEVER A GOOD IDEA, a useless marketing "feature"! Yes a quality shock is more expensive than a high volume manufactured heavily advertised brand, but you are paying for quality parts and high precision manufacturing that fit and work, and usually carry a lifetime guarantee. The difference is easily appreciated and immediately apparent.
shock mount wesley49 1967 - 1972 F-100 & Larger F-Series Trucks 7 01-26-2016 04:30 PM
What shock height to go with shackle lift tennesseex Excursion - King of SUVs 4 09-04-2015 09:36 AM
New shocks? BKM-WR3 1987 - 1996 F150 & Larger F-Series Trucks 4 02-13-2015 01:57 AM
Shock absorber Powerstoke73 1999 - 2003 7.3L Power Stroke Diesel 3 08-03-2014 09:23 PM
Opinion on replacment shocks 84StraightSix 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-22-2014 03:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
