Best turbo for engine rebuild? - Input Needed! - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-17-2014, 12:16 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Quote:
Originally Posted by OldWoodsDiesel View Post
Wouldn't that be a tuning thing from there moose? ..
Glenn is the guy to ask. I think he's got it pretty much licked but still a haze. Unless your able to get live tuned. I have to put on a heck of a lot of miles for that
Old 07-17-2014, 07:23 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
yeah, its looking more and more I may go that way. I actually just found one on CL. its off a cummins, but looks to be the same as this one I've been eyeing up for a few days now: Borg Warner S300SX3 S366 66MM .91 A/R
the CL one supposedly has just 1500 miles on it. if I can get it for ~$400 I may just do it.
can anyone fill me in on what specs may work best on our trucks with my proposed setup? it seems like there are alot of options in terms of housings, turbines, compressors, etc. again, I'm planning on stage 2's, T500, e-fuel and a TS chip. and obviously the 6637 intake and the biggest DP I can make fit.
like a lot of people, I'm looking to make power, but also for reasonably quick spool up.
here's the specs on the one in the link above:
Wheel Dimensions:
•Compressor: 66 mm inducer / 91.4mm exducer, with Extended Tip Technology.
•Turbine: 80 mm inducer / 73 mm exducer.
Housings:
•Compressor: Large 4.00" ported anti-surge air inlet / 3.00" charge pipe outlet
•Turbine: .91 A/R Twin Scroll, with 'T4-style', divided entry, and 4.21" v-band discharge.
and here's another similar one on the same site. although, this is an S360 instead of S366 - looks like same housing just smaller guts inside?
Wheel Dimensions:
•Compressor: 60 mm inducer / 83.5 exducer, with exclusive Extended Tip Technology.
•Turbine: 76.2 mm inducer / 67.5 mm exducer. Cast in Inconel 713 for high-temperature operation.
Housings:
Old 07-19-2014, 12:24 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
i am able to get s366 turbos from borg warner for 550. rebuild knows that pm me if you all want one
Old 07-19-2014, 12:25 PM
rodneywar's Avatar
i also made 375 hp with stage 1 injectors and a 366 turbo back when i had em
Old 07-19-2014, 12:55 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
Thanks Nick but I don't have it licked. Its better then it ever has been but live tuning would be great. I've got three chips, gear head, Wildman, and no limit. Gear head will give me free reburns but as soon as I installed his chip and put it into stock heavy tow mode (which they called it), I had to put my foot on the floor to get it to take off. I called him and he said that heavy tow was stock tunes. WHAT???? I asked him if he expected me to tow 18K in stock mode. He then said to use economy or street mode. This completely turned me off. His chip is laying on the floor behind my back seat. Wildman has great power and I used it a lot until after three reburns, he still wouldn't smooth out the cruise, its jerky. Also, right from the start with just barely touching the pedal it would blow out a ton of black smoke even if you were trying to take off easy. I then reverted to my old No Limit chip in which I had asked him to turn up the power on but had never tried it. That's the chip I'm running now and it works real well. I have a smooth cruise and great power. Not as good as Wildman's but still as good as its going to get without real high EGT's. The smoke isn't near as bad and the higher shift points in heavy tow mode and almost perfect. The rest of the positions are a lot lower shift points which is fine if your not towing heavy. I still after all these years want live tuning though.
Old 07-19-2014, 10:23 PM
Quote:
Thanks for the offer Rodney - i really do appreciate it. i actually just wound up buying one from Smeding Diesel though. they were running a deal for $600. not as good as yours :-), but it was free shipping, so close maybe.
seriously - thanks for the offer, though.
now i need to start figuring on my DIY mounts and up pipes though. i can make the mount easy enough, but the up-pipes will be trickier. i may actually try bending up the sections at work. not sure if we have a 2" die with a tight enough radius though...
An Engine Rebuild/Refresh Thread OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 300 06-26-2015 07:17 AM
Niks DIY E fuel, bellows, s366 and trans rebuild nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 39 02-18-2015 03:37 PM
DIY S300/S366 Thread OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 84 12-01-2014 09:25 AM
Another S366 Turbo Question Thread nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 12 05-03-2014 09:53 AM
S366 VS Full Force BASB Bell 300 series Turbo nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-02-2014 06:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
