roadrash63, the truck build - Ford Truck Enthusiasts Forums
Old 07-15-2014, 07:34 AM
roadrash63's Avatar
roadrash63 roadrash63 is offline
roadrash63 is gaining momentum as a positive member of FTE.roadrash63 is gaining momentum as a positive member of FTE.
the truck as I got it
600.00 had not been on the road for 12 years !
1985 f250 300-6 4speed, 4x4
Old 07-15-2014, 07:48 AM
roadrash63's Avatar
the engine
eec IV
would not idle
replaced carb yfa duraspark dist and hei ign.
burned up 2 duraspark modules left key on...oops
wont happen with hei.
cheaper too.
much better !
gee whats that hole in the firewall for ? hmmm
tips on removing the computer from the dash ?
Old 07-15-2014, 07:59 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I don't know about the later trucks, but in 82 the computer and its inputs and outputs were a standalone system. In other words, the computer and all it's components could be removed without changing anything else. I assume this was because they were still making models that didn't have the computer so needed the base wiring to be able to work standalone.
So my approach was to follow the wires from the computer to determine if it was standalone. Once I realized that was the case I cut the harness close to the computer and started extracting the wires from the wires that were to stay. But, that took some doing as they were frequently wrapped around each other, were wrapped in the same covering, or shared common attachment points. Then, as I got each wire back to the sensor or controlled device I knew I could remove that device.
Again, that was on an 82 and I don't know if that'll work on yours.
roadrash63's Avatar
frame work
after..
before
I used rust converter with vht frame paint on top.
Old 07-15-2014, 07:04 PM
roadrash63's Avatar
crusty rusty parts off...
refurbished ford parts on
(jy)
Old 07-31-2014, 05:38 AM
roadrash63's Avatar
progress ...
paint is krylon ultra flat woodland green.
Old 07-31-2014, 06:22 AM
Gary Lewis's Avatar
In a spray bomb? That looks pretty good for that.
Old 08-03-2014, 04:33 AM
roadrash63's Avatar
yeah
krylon woodland camo with fusion, there is an olive drab which looks like baby ****...woodland ultra flat. the caps are very similar !
a real paint job is the last thing on my list...
ive only got 8 hole steelies now green or black ?
ive done a whole truck woodland camo before a 79 Chevy 3/4 ton, everyone incl an ex drill sgt. thought it was real army truck.
a real conversation piece !
Old 08-04-2014, 04:12 PM
roadrash63's Avatar
jy bumper with back up siren and 7 point trailer connector.
truck also has trailer brakes.
replaced rear non slider with slider from my old f150
no its not cracked...must be the soap !
slider in, PITA !
cant wait to get the bed on !
Old 08-04-2014, 04:22 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
We used to laugh at the older chevys and how they rusted out. The metal these frames are made out of is pitiful, we have no solid ground to stand on and make fun of the chevys anymore as far as rust.
Look at any old truck from the 30's, 40's, 50's and 60's, and it will have rust on the frame, but it will be smooth light rust unless it was buried in the dirt. They don't pit and disintegrate like these frames do.
Old 08-04-2014, 05:31 PM
roadrash63's Avatar
id love a fifties truck !
when I was a kid late 70's I worked at a union 76 .
my boss had a sweet 59 .
I got to pull in and out of the shop, that was it.
b/c I knew how to drive 3 on the tree.
learned on a Studebaker truck !
Old 08-17-2014, 05:05 PM
roadrash63's Avatar
update
I installed a Holley fuel pressure regulator to help fix my fuel pressure issues...this was after I replaced the carter hi flow that was installed with an airtex unit.
no change so I put on the regulator.
why I need a regulator on a stock setup is beyond me !
I swapped out the yfa which I rebuilt to specs. as a step to eliminate it in a quest to resolve " volcano carb " problem...
with this autolite 2100 that I rebuilt a couple of years ago and I knew it ran fine.
cleaned up the wheels had planned to scrap, passable with flat black paint !
the gray stuff is anti seize.
the tires will be junked soon.
I also replaced the dr. side caliper and pass side drum.
also found an article about me & the truck !
Got $600? Start a 1985 F-250 Build! | Ford Trucks
Old 08-17-2014, 07:03 PM
Gary Lewis's Avatar
Yeah, we talked about that while you were gone. Welcome back. But, I don't think you said how the truck ran w/the 2bbl. Or, did you?
Old 08-26-2014, 11:16 AM
roadrash63's Avatar
i dont remember what we were talking about.
Quote:
anyways I got the fuel problem fixed w a Holley regulator set at apx. 5 psi.
but it kept dying after like 2 mins so I replaced the coil pick up via a new dist. 49.00 advance auto.i figured that the vacuum advance diaphragm was pretty old anyways.
so it actually idles now at apx 900 rpm still have to hook up the sun tach. and manual choke. I also want to scrounge up a factory air cleaner for the 2100. so can have the cold weather accessories.
seems to run fine with the 2v carb but haven't taken it on the road yet b/c its not insured now...
oh yeah got rid of the black stripe didn't like in the sun light, maybe b/c its ultra flat too ?
temp throttle bracket...
next bed prep and install !
Old 08-27-2014, 01:51 PM
roadrash63's Avatar
hoods on !
finally got the hood on.
finally starting to look like a truck again !
48 F1 Jeepers Creepers killjoybjg 1948 - 1956 F1, F100 & Larger F-Series Trucks 41 02-01-2017 05:51 PM
Ha ha roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-27-2016 07:06 AM
c6 linkage part needed see pic roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-08-2016 08:09 PM
funny vin ? decoder dint work roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 02-26-2016 05:50 PM
Vietnam Veterans Car Show smallello 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 05-21-2015 06:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
