Trailer brake don't work - Ford Truck Enthusiasts Forums
Old 07-14-2014, 08:02 PM
Sclock Sclock is offline
Sclock is starting off with a positive reputation.
I have a 2004 f250. Bought used with no owners manual. My trailer brakes quit working. I went to ford dealer and got the fuse diagram. Fuses are good. I switched brake controllers and still no luck. I know the brakes work on my trailer cause my buddy used it with his truck and had no problem. The deal said there is a relay for trailer brakes but could not or would not tell me the location of it. Any ideas????? I'm out of options other then taking it to someone to work on it.
Old 07-14-2014, 08:38 PM
BossGasser BossGasser is offline
BossGasser is gaining momentum as a positive member of FTE.BossGasser is gaining momentum as a positive member of FTE.
Did you test the fuses or look at them?
Old 07-15-2014, 05:12 AM
Pit Crew's Avatar
Pit Crew Pit Crew is offline
Pit Crew has a good reputation on FTE.Pit Crew has a good reputation on FTE.
The relay is under the hood. Not sure which one, but if you just switch them around one at a time untill you find the bad or missing one.
Old 07-15-2014, 05:17 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I moved this to the towing section for some additional help. Check our tech folder as well.
check here for a copy of your owners manual. That should also help to locate which relay is for the towing:
Owner Manuals | fleet.ford.com
Old 07-15-2014, 05:28 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is online now
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
Check the brake switch located on the brake pedal. We had that problem. It will also affect the cruise control and several other functions of the truck.
Old 07-15-2014, 06:31 AM
RV_Tech's Avatar
RV_Tech RV_Tech is online now
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
Fuses or connection between truck and trailer about 99% of the time. Almost never the brake controller.
Steve
Old 07-15-2014, 08:02 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is online now
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
Agree with RV_Tech. Plus, if you swapped controlelrs and still had the issue, that also points to the controller not being an issue. Start testing the outputs at the rear bumper and go from there.
Old 07-15-2014, 05:33 PM
Problem solved..... I bought a new relay and started swapping them out until I found the bad one. Probably not the best way but it worked. Thanks for every ones input.
Old 07-15-2014, 05:35 PM
senix's Avatar
Thanks for reporting back.
trailer, no brakes, no lights, nothing old farm truck Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 14 03-12-2017 11:34 PM
Trailer connector-no brakes or turn signals RUSTANG67 2009 - 2014 F150 4 07-18-2015 07:25 PM
First tow and trailer brake observations tracyclifton 6.7L Power Stroke Diesel 7 07-09-2015 11:08 AM
trailer brake fuse# 2012 F-150? Derekgammage Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 14 05-15-2015 07:15 AM
Fusible link for trailer lights and brakes? metriccar 1987 - 1996 F150 & Larger F-Series Trucks 7 03-25-2012 04:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
