A Kick In The Nads..
#76
The first thing to know about a 6.0.... use international or ford parts only. A trip to autozoo or the like is going to generate a repeat customer for lifetime warranty junk. These trucks are so electrically dependant it is rediculous and it makes them a real pita at times why cut corners with junk parts.
#77
Yes. His guy is wrong on that one. Don't mean he's stupid or not knowledgable, it does however prove nobody is 100% correct 100% the time.
#78
The OP is wrong on the ICP sensors. When I replaced mine a few months ago, I sent my wife down to the Ford dealer with the old part. The parts guy brought out both the new and old style ICP sensors. Both have the same thread. The only difference is the size of the sensor body. I am sure there are other differences, but to the common man and eye, I couldn't tell.
I had 3 folks tell me to get the later model one and I didn't out of fear of it not working. Wish I would have since it would have made the install easier!
To the OP.....The folks on this forum won't lead you down the wrong path. They have helped me in every situation I got myself into with this truck! That being said......keep tossing the hate and the help will dry up I can guarantee that.
#79
#80
And to throw an almost TOTAL hijack into this thread, not only do the ICP sensors interchange just fine, the IPR valves will interchange just fine ALSO.
And lets don't mention that I'm STILL running my ORIGINAL ICP sensor on it's second (hybrid 03/04) motor, along with numerous other original electronics.
TO THE OP: We are ONLY here to help you. Some of the most knowledgeable people in the forum (Bismic, Cheezit, Rusty, Mustang and MANY others) have given you excellent advice. If it had been bad or wrong it would have been corrected quickly. We don't pull (or throw) punches, we just tell the truth.
#81
If it walks like a duck,Quacks like a duck and even looks like a duck then
it must be a
The thread started out with troll like title. You ask for help then when it is given
by people that know this engine quite well. You spit it back at them.
To me and a lot of others this is what a troll does.
So yes I think your a troll. Go back under you bridge and sell that truck.
Sean
it must be a
Sean
#82
I have to succumb a little to the temptation .....................
Some people should not own a 6.0L!
Knowing the engine intimately (or having a friend that does) is very important to having a positive experience! These forums are amazing, but if you are too hard headed to learn the truth, then you are destined for frustration and anger (and the OP seems to already be there). I like what Rusty said ....... "being wrong doesn't mean someone is stupid". However - ignoring the truth when confronted with it (ie catalinaflyer's earlier post) and alienating forum folks, well that may be a different story. The flip side of the learning process is ..... when you are wrong - admit it, accept it, don't repeat it, and move on. I doubt that any of that will happen here though.
That being said ............ I scrounged up a 2003 ICP and installed it in my truck (I didn't cross thread it either - lol). At the suggestion of Moe (cheezit), I am going to see if there is a possible upside to the install. More on this later!!
#84
#85
#86
#87
How far off am I...?
#89
So the PCM gets more accurate or faster and accurate feedback on what it is asking the IPR to do. It is another **** to turn in the complex system that creates a high pressure pulse of fuel.
If we have to "wait" for ICP to come up, we can't pulse the injector at perhaps the most optimal pressure/width for what our intended purpose is. We could send potentially different pressure/width fuel pulses, maybe even within a revolution, given the electronics are far quicker than the hydraulics of the system...
I'm not sure what it would help with stock tuning... But maybe it could.
Am I getting colder? And how come nobody else is playing?! Are they worried of a:
