A Kick In The Nads..
#62
It is nice of you to have hung in here Mark....
#63
I guess he did not even believe an owner that has used the new part in an early engine (post #53 btw).
Seriously though - in the last year, we have seen multiple reports of rebuilt HPOPs (early model year) failing prematurely. Some right out of the box. Seems that the Adrenaline pumps are doing better (aftermarket). There have even been a few NIB IPRs fail. This is the helpful stuff that is available on the forums. I wonder whether or not we will see more of this as the years go by. It is one way for a company to save money (ie change parts suppliers to cheaper ones on the older model years). In my search for muliple ICP failures, I did find a few NAPA ICP's that failed early. I also found numerous 7.3L ICP failures - interesting. I truly don't find much on annual 6.0L ICP changes after the sensor was updated.
#64
#65
I'm pretty sure I didn't cross thread mine in because I reached in from underneath and threaded it with my fingertips over the heat shield then used a socket on two wobbles to turn it the last turn to seal the o-ring.
#66
One trick to help prevent cross threading is (works for me very well)
to take the new part and press it into the opening and turn like you trying
to remove it while keeping pressure on it till you fell the thread ends drop
past each other. Then you go from removal direction to install direction.
Sean
Sean
#67
I was. looking for INTELLIGENT Input. that has been tried.& works.. - I. will use what works, IF. PROVEN..when i run what has been posted by a friend that IS. a Ford Diesel tech. He, Tells me why Not. to do the change.. I go with what HE. KNOWS.& what he shows me.& what I see. proven to work.. OR. I Stay whth what ford pays engeneers a lot to figure out..
#68
How to prevent cross-threading a bolt, screw or any threaded fastener - YouTube
Sean
Sean
#69
REALLY.?.! First I had one guy, tell me to try unpluging the ( I.C.P. ) to see if a miss goes away. - yep, it started up & the miss went away.. OK, Then Im Told to use what I Know to be the part Number to a nother truck.- (Different year & running change) so I text, & run this by my friend at Ford,- (Diesel Mechanic) & Owns the same truck..who tells me the Threads are different. I mention this. and the PEANUT GALLERY CHIMES IN, to Insult, & berate me.? Like A Bunch of Juviniles.. Because I questioned putting A Part. I knew to be for a different year, on My motor.. & Go On To Berate anything Iv said.- The Cost of the part. $167-(at all local dealers)- i First did. try ordering one on line,- Cost less. but was out of range,& didnt work.& I was Told Thats Why Everyone doesnt go buy the $50 part,- why wouldnt you..- IF> it worked.. Now Here is The Coreect Ford Part,Lets see..& yep ran good a year..This is why I am not quick, to just throw $167 on a wrong part Unless I know it works.. NOT.- A guy posted, I heard.. SO IF YOU Take ANYTHING Thats Posted, AS Correct,- And Bet Your Truck,&LIVELIHOOD, on.. A Guy Posted. I Heard.. Go Ahead.. ha ha.! OH.. Just Because someone Gives, "Advise".. doesnt mean "YOU""HAVE" To Take IT.. USE What Is USEFUL To You..- But Check Facts First.. Its Just Info.. Dont Have A Stroke, Over it..
#70
You just can't help some people.
#72
Ya, Just cant Help some people.? Actually, Unplugging the i.C.P.- to determine that was at fault.. did help.. (Thanx For That) But I'm Curious, Usually When Someone,Wants to Try, To Talk Down to me. Or looks To Be condescending, - (They OBVIOUSLY DONT KNOW ME.) It Is because Someone Was Abusive to Them. & Now They Carry On This Illness.. sad..
#73
I challenge you to go down to a Ford service department and get both styles of sensors in your hands. Prove Mark wrong, videos normally work well for this. Match up the threads and show us pictures of why it won't work.
After seeing the proof, we will believe you(your mechanic). If it comes out with the same threads, apologies would be recommended.
#74
I'm sorry if you have taken anything I have posted as being berating, condescending or belittling.
I just wanted you to know that I also own an early build 04 and I have used the part from the late build 04+ on my truck just this weekend. It screwed right in using only my fingertips so it's highly unlikely that I cross threaded or forced it to thread. Yes they may technically be different threads but how different?? Would I use the wrong threaded part in an airplane I plan on burning a hole in the sky with? Not on your life or mine but on a sensor on a pickup truck is a different story. Yes if it comes out at highway speed there's a chance that it will pump enough oil out fast enough that there could be internal damage before getting it shut down. How big of risk? I don't know but one I personally felt was small enough to go with the advice of many on this site and try the part.
You came on here complaining of a failing part that Ford sells with a 2 year warranty yet you said you had to purchase a new one after one year. Many offered advice of trying a different part number that many on this site, myself now included have had success with. You then turn around and say your guy says it won't fit and infer that the people on here who don't know you from Adam are all wrong because your guy says so.
If your going to have your guy do the work and take his word then that's your choice and there is absolutely nothing wrong with that. The correct part for your year truck will fit period. It will do it's job provided there isn't anything else wrong in the system. Now will it do a better job than the newer one, probably not, they both provide the same data stream to the computer but the newer one may be of a new design and therefore last longer. No one said you HAVE to use the newer part, some just offered you might want to try the newer part but your guy by your own words says it won't work so don't use it.
I have had a demon child of a truck every since the wife brought it home. However I have saved $1,000's just reading this forum and taking the advice offered by many on here and I could give a rats rear end whether they own the same truck, have personally tried the advice they offer to me or if they have ever worked as a Ford mechanic let along have some master rating. I have not once questioned the advice and EVERY SINGLE TIME I have followed the advice it has fixed the current problem or at least shown me where the problem is at.
So with all of that being said you should probably decide whether your going to follow the advice of the many on here or your mechanic but to try and question the advice of each against the other is only going to get you conflicting advice and possibly create unnecessary hard feelings.
I'm sure you have heard the phrase "There's more than one way to skin a cat", well there's also more than one way to fix a 6.0.
#75
