picking up a 400 and will rebuild - Page 2 - Ford Truck Enthusiasts Forums
Old 07-26-2014, 05:05 AM
Wodahs Wodahs is offline
Wodahs is starting off with a positive reputation.
yer it wasn't a 400 was just a 351m have a 400coming that's been magnafluxed, straightened and precision ground on each rod and main but after I get it it will still need to nitrated and rechecked , have organised a 4 bolt mains kit with a stud kit thro TMI , hope to see how my heads are going next week when I (hopefully) drop the block off to be cleaned and measured and machined as necessary and then to work out where I stand with pistons am now thinking may get the machinist to bush the conrod wrist pin to suit cleveland pistons after he has shot peened them
Old 07-26-2014, 08:19 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Why not go with Tim's pistons?
Old 07-26-2014, 08:55 AM
may do am talking with him bout this but also keeping my options open still and there is a larger variety after modding to cleveland wrist pin size for what im going to be looking for to achieve what I need to make this motor run with what im throwing at it
Old 07-26-2014, 09:32 PM
BuzzLOL BuzzLOL is offline
BuzzLOL is starting off with a positive reputation.
. For blower use, would think you would want Tim's 351C pistons with the bigger '400' size wrist pins... or hone out the pin hole in your other pistons of choice...
Old 07-26-2014, 09:36 PM
Gary Lewis's Avatar
Agree. I'd want all the wrist pin size I could get. The C wasn't a torque engine, but that's what the 400 was designed for, hence stout things like the wrist pins.
Also, I'd have the rods shot peened.
Old 07-26-2014, 09:59 PM
. And, the bigger pins not only stronger but have larger bearing surface to handle a bit more pressure on them...
aode info what from what is ? Wodahs Clutch, Transmission, Differential, Axle & Transfer Case 1 12-16-2014 04:56 AM
Torklift StableLoad Install and Review Tom 2009 - 2014 F150 30 08-13-2014 10:22 PM
hi Wodahs New Member Introductions 4 07-13-2014 08:10 PM
Think I need to trade! Tom 2009 - 2014 F150 33 02-28-2014 11:47 PM
Funny trailer tire wear Tom Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 16 08-04-2013 10:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
