2009 Blend door? HELP!
HEEELP! got in the truck tonight and she is blowing nothing but cold out the drivers side but the passenger side works as advertised for temp settings. I have been trying to see if there is a self test mode like the earlier year trucks have to see if there is a code. She is dual zone climate/digital so its an EATC if I am not mistaken. I have tried power cycle, pulled and re-installed climate fuse after inspecting. Tried some of the earlier year self test button combinations to no avail. I did notice if I hit defrost a few times after hitting the power and defrost that the temps would go all 00 but I don't know if that is what I am looking for. I probably know my answer which includes tearing out the dash but I was hoping against hope someone might know how to proceed. Bought her with an aftermarket power train warranty so electronics are off the table for warranty. I know the stealership will charge out the rear to fix it too. All signs so far point to a blend door which is not good at all.
no have not done anything to my truck in a while and it was not cooling related. I have full control of passenger side but the drivers side is one temp (cool). I Did just make an observation on the way home from work that the flow through rear passenger vents temp stays at the same temp as the drivers side and does not adjust with the primary temp ****. I can use the drivers temp control and the passenger side works as advertised as well as passenger control for the dual climate but no change for the drivers side and rear passenger no matter if I am on defrost, dash, floor, etc.
sorry I did not get your last post. if you have absolutely no heat on the drivers side and heat on the passenger side front and rear passenger and no heat front rear driver then this suggests the actuator motor is not working weather or no the motor is at fault or what controls it could be the issue. do you want to run the diagnostic test sometimes you can have many issues that this test will not show it would be worth the time to do it before you rip in to the dash.
Yes I was hoping to try to run the diagnostic to try to narrow it down. Sorry, tried to explain that the drivers vents and the rear seat console vents stay the same temp which is cool (AC does work through these vents it seems) but no heat will come from them. The passenger front vents work just fine and the temps change as requested from hot to cold. I can switch both driver and passenger front vents to defrost,floor and panel but the temps wont change on the driver side. hopefully that explains it better.
The self-test can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when the self-test is activated.
To enter the self-test, press the OFF and DEFROST buttons simultaneously and release, then press the AUTO button within 2 seconds. The display will show a flashing blower icon for 20 seconds, after which all vacuum fluorescent segments will be displayed if there are no on-demand DTCs present. If DTCs are present, the EATC module will display "00 00" and then on-demand DTCs. Record all DTCs displayed.
If any DTCs appear during the self-test, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control (EATC) Module Diagnostic Trouble Code Chart and follow the ACTION for each DTC given.
If a condition exists, but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation.
To exit the self-test and retain all DTCs, press any button except DEFROST. The EATC module will exit the self-test and retain all DTCs.
To exit the self-test and clear all DTCs, press the DEFROST button. The EATC module will exit the self-test and all DTCs will be cleared.
Always exit the self-test before powering the system down (system turned OFF). Once the self-test is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
I found this for a 2007 model this should work for your year truck as long as you have this setup which I believe that you do. have you seen or tried this test procedure before.
well it was better to be sure than to take the wrong action. it is very common for the blend door actuators to fail. most of the time you just go ahead and replace the motor the next step would be to verify the blend door motor has control and if it does then that leaves the blend door or the actuator. these heater plenums do not use the older style blend door so it parts of the plenum and usually does not fail you must remove the dash board to do either repair. this job is not to bad takes less time than the older model pickups and I have never tried to access the left actuator other than pulling the dash and do not see it at all possible to get to but never tried to without removal. I am sorry the self test did not help but its a lot better than pulling the dash just to find out you made the wrong move.
would you like to test further or not again this is all to be sure you know what's wrong and have complete knowledge that what ever is done will fix it.
