How much horsepower does a stock 7.3L have???
250hp/505 lbft torque = auto transmission
275hp/525 lbft torque = manual transmission
Power Stroke Diesel Timeline
I think you would be lucky to see something like 210 HP at the wheels stock.
Are you doing the simple math of Stock = 250 then DPs 80DD tune must be 330HP then?
I believe more goes into it than that. IIRC it would take more than just intake, exhaust and a stock DP tune to get to 330 HP at the rear wheels.......heck I think 325-350hp is the sweet spot for ACs vs. the stock sticks, unless you like high EGTs.....
BTW, you slapping gauges on that rig?
If you put a dip chip on it...
Just sayin...
You will be locked into buying tunes from dp.
Putting a chip on it should be last on the list for performance modifications.
Gauges. Gauges. Gauges!
Air in and out.
Fuel system updating.
Turbo compressor wheel at least.
You really should make sure your engine is healthy enough #1 and get it to 100% healthy in the stock configuration before trying to add power.
Throwing a chip on it and stomping the go pedal is a great way to end up looking for a replacement engine sooner than you would like.
Just sayin...
Air in and out.
Torque accomplishes nothing without at the very least a time reference.
Horsepower is the only thing that matters when trying to get something done.
A stock-ish 99-03 7.3L will put down right about 200 RWHP.
