Everything look alright down there (rust, leaks)? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-14-2014, 11:00 PM
loudoun loudoun is offline
loudoun is starting off with a positive reputation.
I don't think this is a lot of rust. I think it looks pretty good, but I don't have a lot to compare to.
Based on what you've seen, how would these pictures rate on a scale of 1-10, 10 being in really good shape. Please let me know if you notice anything that looks like it would need attention.
RE: rust, what is the best way to keep it under control?
Thanks
Old 07-15-2014, 01:24 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
By any standard, that rust doesn't rate any concern. You could paint any clean rusted surface with Hammerite, if you like, but unless you're moving to the rust belt, I would leave it alone. That looks like the underside of many 13 year old trucks with 100-200K miles, and better than many.
Old 07-15-2014, 04:18 PM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
That doesn't look bad at all. Keep it washed under there. Looks like there is some residue in one of the pictures (salt?). A trip to the undercoater or possibly a WD-40 soak down wouldn't hurt.
Old 07-16-2014, 01:22 AM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Looks pretty normal to me.
However, if you really must have that rust free look....
POR15 i believe is the name. Just brush off the loose rust, spray on and it will bond with the rust and protect it from getting worse. Looks flat black when dry.
Kinda pricey tho... At least to me.
Can anyone identify this step van for me? Jim Collier 1947 and Older Ford Trucks 11 11-17-2015 06:05 PM
Just a little F1 metal work pweng1 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-04-2015 05:51 PM
York Pa ZOOT 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-23-2015 07:47 PM
OT: Ford Barn ZOOT 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 04-07-2015 03:50 PM
what is all this red stuff?? maxtruck00 6.0L Power Stroke Diesel 6 07-22-2014 09:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
