Yeah. I went out and bought a compression tester and all were at 500+ while number 5 was around 290-310. Took The head off to check it out and the piston didn't rise to TDC.
^^^^^ Device error, in all likelihood. The key is, one came up considerably lower, which led to the exploratory surgery. Good sleuthing on the OP's part.
