2001 f150 5.4 no power bad mpg
Old 07-12-2014, 04:31 PM
thejim42's Avatar
thejim42
thejim42 is offline
I have a 2001 f150 4x4 with the 5.4. Just turned 141xxx and the last couple weeks my gas mileage has been getting worse and worse I have less and less power and I don't get any power until I'm over 3500 rpm and even then there isn't much. Oil changes regularly every 3000-5000 miles. Around 120xxx it got a new intake, new coil packs, new plugs. Up until about a month ago I was getting 14-15 mpg in town now I don't get that on the highway. I have no check engine light, and it doesn't miss fire. Runs great. Just doesn't have any power
Old 07-14-2014, 08:10 PM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
I would scan for codes anyway...sometimes the CEL light won't laminate with a code stored...its suppose to...maybe your CEL bulb is burnt out?
Sounds more like you got a vacuum leak some where? WAG
Are you sure you don't have a brake hanging up or E brake pads lost their moorings...maybe a bad wheel bearing/s...point is many things can account for poor MPGs .
Are you low on tranny fluid?
Mehrmannfarms
Modular V8 (4.6L, 5.4L)
05-04-2013 09:42 PM
quiacato
2009 - 2014 F150
26
08-02-2012 08:45 PM
marv02
11-06-2011 06:24 PM
chief173
1997 - 2003 F150
03-21-2011 07:19 AM
greg53
1999 to 2016 Super Duty
22
01-27-2007 10:10 AM
Quick Reply: 2001 f150 5.4 no power bad mpg
