1950 F1 4 spd nonsyncho transmission - Ford Truck Enthusiasts Forums
Old 07-14-2014, 05:31 PM
craignmullis craignmullis is offline
craignmullis is starting off with a positive reputation.
I removed this transmission from a 1950 F1 and would like to know its origin. It is not original to the 1950. It supposedly came out of a 1948 Ford F1. There are several numbers on the top and right side. On the top front is 8 8RC 55002 (above what looks like an inspection plate). On top behind the shifter is G8T 7222. On the top to the right of the shifter is DG&M. On the right side is OIT-7006, below that is DG&M, and below that is N4.
A couple of questions for anyone that might know: when was this transmission made? Is there a source for parts? Any gasket kit available? Any other information?
Thanks for any info you can provide.
Old 07-14-2014, 05:36 PM
1952henry's Avatar
1952henry 1952henry is offline
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
The spur gear transmissions Ford used in that era were Warner Gear T9s. Joblot has gasket kits. May have other parts as well. Bearings can be cross-referenced at any bearing house.
Old 07-14-2014, 06:41 PM
Great!! Thanks for the info!!
51 - 7006 DG&M N2 transmission mike.rogers 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-31-2016 05:25 PM
Flathead with Overdrive 1950FordF1 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 09-26-2014 03:10 PM
4 spd non-synchro transmission craignmullis 1987 - 1996 F150 & Larger F-Series Trucks 2 07-14-2014 05:32 PM
1963 F100 4x4 Transmission KsCop 1961 - 1966 F-100 & Larger F-Series Trucks 46 07-22-2013 12:59 PM
5.8 winsor new belt tensioner & Belt will not fit, HELP! DGM 1987 - 1996 F150 & Larger F-Series Trucks 4 05-17-2012 08:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
