mustang II ifs parts - Ford Truck Enthusiasts Forums
Old 07-14-2014, 05:15 PM
Tushy Tushy is offline
Tushy is starting off with a positive reputation.
Hi Guys,
I've got a mustang ii front suspension on my 56 f100.the lower arm shaft is broken and I need the replacement.it's a high tensile steel,could make some maybe but dont know what strength .anybody can help me with some idea where can I buy maybe?it's 5/8 thickness and 13 inch length.I need 2 in ASAP.cheersfor any help,Tushi
Old 07-14-2014, 06:32 PM
jniolon's Avatar
jniolon jniolon is online now
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
Quote:
Originally Posted by Tushy View Post
Hi Guys,
first I wonder what broke a 5/8" steel bolt... something hit it way hard, right ?? what other damage was done ?? if the bolt sheared, surely the lower arm sustained some damage... The bolts can be found... Fastenal can order them... I'd check them online or they have a store in every county in the us... just get them to quote 13" grade 8 carbon steel bolts...
later
John
Old 07-14-2014, 10:32 PM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Given that the OP is in the UK I imagine that any recommendation for local US suppliers will be problematic. I would find the manufacturer of the IFS and file a complaint...as John said, there must have been something out of the ordinary happen to cause that sort of failure.
Not to be nit picky but for this application you would want a bolt with a high SHEAR modulus, not so much a high tensile. Tensile strength is measured along the axis of the bolt whereas shear is measured at a 90 degree angle to the axis. A cylinder head bolt needs high tensile strength since it is stretched along its axis...the lower control arm shaft experiences more of a shearing action at a 90 degree angle between the control arm and the mounting point(s) on the crossmember. I am not sure that this is the cause of the failure but sometimes my engineering background just jumps out...
Old 07-15-2014, 02:57 PM
re
The reason why it's broken because I 've bought the truck as a project and suspension was already fitted.but I didnt relies they forget to weld the sleeve
with the bracket to the axle.and I took the car to paint and just broken.
I think I found a company who will make them.cheers guys.tushi
Old 07-15-2014, 03:23 PM
CharlieLed's Avatar
Sounds like you have it solved, good luck with your truck!
fenders hole Tushy 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 01-19-2016 05:06 PM
56 headliner Tushy 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 11-16-2015 03:20 PM
grill Tushy 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-06-2015 01:57 AM
mustang II shocks Tushy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-24-2014 12:58 PM
colour Tushy 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-23-2013 04:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
