272 Smoking when shut off? - Ford Truck Enthusiasts Forums
Old 07-14-2014, 09:13 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
I rarely open the hood of my 56 F100 after driving because it's such a PITA. But yesterday I opened the hood after taking it for a 5 mile run. There was a pretty fair amount of smoke coming from the ole 272's oil filler cap. I started the engine again and no smoke, stopped it and it started smoking again. The truck has a road draft tube (no PCV) and both the screen in the road draft tube & the filler cap are new (less than 100 miles).
Is this an indication something's wrong? Any opinions or solutions?
Old 07-14-2014, 04:24 PM
pintoplumber pintoplumber is offline
pintoplumber has a good reputation on FTE.pintoplumber has a good reputation on FTE.pintoplumber has a good reputation on FTE.
I'd bet it's not smoke, just hot vapors. What kind of condition is the motor in? Dennis
Old 07-14-2014, 04:30 PM
Not sure. It ran well 25 years ago then sat until last year. I changed the oil & Filter, replaced the fuel pump, road draft screen and oil cap, cleaned out the fuel tank & carb. Started right up. Ran it for about 50 miles and changed the oil and filter again. Seems to have plenty of power, starts right up. Has a 4 barrel ford manifold with a 390 CFM Holley.
Old 07-14-2014, 06:52 PM
A pcv system would probably take care of that. Personally I like the smell in the garage when I bring the truck or car in. Dennis
Old 07-14-2014, 08:25 PM
It only smokes after I shut it off. Been thinking about changing over to a PCV system but was afraid the smoking might mean that the ole gal is getting too hot. I did have the radiator repaired and changed the water pump, hoses & thermostat.
Also added Petronix electronic ignition and coil.
Old 07-14-2014, 08:42 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Engines of that era produce lots of blow-by fumes, vaporized or misted oil and steam from condensation in the crankcase "burning off".
Old 07-16-2014, 09:48 AM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Quote:
Originally Posted by 85e150six4mtod View Post
... lots of blow-by fumes, vaporized or misted oil and steam from condensation in the crankcase "burning off".
That is exactly why you should install a PCV system to get rid of all the "blow-by fumes, vaporized or misted oil and steam from condensation" from your crankcase.
Your engine will love you for it. Good for the environment also.
Old 07-16-2014, 06:15 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
It's normal for that era. The road draft tube mechanism only works efficiently when moving. Not a cause for concern.
Old 07-16-2014, 08:46 PM
Here's what the ole Gal looks like.
Old 07-16-2014, 09:19 PM
Tedster9's Avatar
Yep. Nice looking mill ya got there!
Old 07-17-2014, 02:05 AM
No surprise there. Maybe a bit on the high side. How long did it run before it was shut down there?
Old 07-17-2014, 10:18 AM
Maybe 20 mins. I just took it for a drive. I had some carb problems and had just replaced the old Holley 4 Barrel (390CFM) with one I had just rebuilt.
Funny thing is the cooling system was still cool enough I could stick my finger in it and not get burnt.
1955 272 Excess Oil Out of Road Draft Tube montego69 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 5 09-26-2016 05:27 PM
Drip tube blow by jamhh 1957 - 1960 F100 & Larger F-Series Trucks 13 12-28-2014 08:02 PM
road draft tube? natedowney Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 12-03-2014 07:50 AM
226 Road Draft Tube for 1950 Ford F1 3twinridges 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 11-30-2014 11:06 PM
223 Road Draft Tube Damifiknow 1957 - 1960 F100 & Larger F-Series Trucks 4 11-15-2013 09:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
