Guess what COOL new item Alliant Power has for us - Ford Truck Enthusiasts Forums
Old 07-14-2014, 05:06 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Talking Guess what COOL new item Alliant Power has for us
AP0040 aka Injector side plug!
Read here.
http://alliantpower.com/sites/allian...a_04-14_en.pdf
here is the tech sheet with the how to.
http://alliantpower.com/sites/allian...b_03-14_en.pdf
Now to find who stocks them and how much.
Sean
Old 07-14-2014, 06:56 AM
dannyboy950 dannyboy950 is offline
dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.dannyboy950 has a very good reputation on FTE.
Good find they must have just added that. I just downloaded their entire catalog last week and it was not in their. Made a note about it.
Thanks
Old 07-14-2014, 07:51 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Have to owe you some reps Sean - great find!
Old 07-14-2014, 08:45 AM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
Good find. I've been working with my part guy for the last week trying to find this again. I knew I have seen it before in a catalog we had at the shop but couldn't find it. Hopefully will have some sitting on the selves at the shop pretty soon.
Sending some reps your way
Edit....starch that. Will send some reps after I spread the love.
Old 07-14-2014, 02:01 PM
Yahiko's Avatar
Well I had not that much (Right,Sure) going on and was looking because I have
the 3 bad ones. One will get taken care of with a replacement injector.
So that leaves 2 that need to be dealt with. I was just doing a bit of aimed random
web surfing and tripped over them.
Sean
Old 07-14-2014, 02:15 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
That's awesome!
Now if Alliant could just source some spools and coil packs (hint hint)
Josh
Old 07-14-2014, 02:35 PM
Yahiko's Avatar
Quote:
Originally Posted by Bullitt390 View Post
That's awesome!
Josh
I still want to drop one in an ultrasonic cleaner with some Seafoam
to see if that takes the varnish off.
Might be a bit flammable
Sean
Old 07-14-2014, 03:29 PM
Bullitt390's Avatar
Sean
Iirc didn't a member try the unltrasonic cleaner and it didn't even touch the spools
Josh
Old 07-14-2014, 03:43 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Josh
I vaguely recall that and yeah the ultrasonic didn't do much good.
Sent from my Telegraph using IB AutoGroup
Old 07-14-2014, 04:04 PM
Yahiko's Avatar
I would think that is would also be chemical dependent.You need
something that is aggressive enough to dissolve or soften the varnish
so that the c=action of the ultrasonic bath can carry it away. That is
the tricky part finding something that will do that and not go BOOM in
the cleaner tank with a bit of heat. Also it has to be something that is
safe to use unlike the old school vapor degreaser agent that did all
sorts of nasty things to the body. If I recall the EPA made them have
a babysitter for it 24/7 so it would not spill or something else.
Sean
Old 07-14-2014, 05:36 PM
Per4mance's Avatar
Per4mance Per4mance is offline
Per4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to allPer4mance is a name known to all
I wonder if Berryman carb dip would work......food for thought
Old 07-14-2014, 05:37 PM
MisterCMK's Avatar
Avid Winter Hater
Some 800 grit sandpaper and brake cleaner works great and takes all of 30 seconds per spool. No sense horsing around with an ultrasonic cleaner.
Old 07-14-2014, 05:48 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Cool find Sean! You may want to consider something like this for the splices.
HEAT-SHRINK BUTT SPLICES from Aircraft Spruce
Or solder and this.
http://www.aircraftspruce.com/catalo...heatshrink.php
Old 07-14-2014, 07:13 PM
jsm180 jsm180 is offline
jsm180 has a good reputation on FTE.jsm180 has a good reputation on FTE.
Gunk Hydroseal used to be a good cleaner, all you can get now is Hydroseal II, still good but won't pull paint like the original stuff. I use a glass jar big enough to hold the part and fill the jar with whatever cleaner I need. Set the jar in water in the ultrasonic tank, works great.
Old 07-14-2014, 07:36 PM
MisterCMK's Avatar
Avid Winter Hater
Or solder and this.
What are you splicing? The connector is just the body, not a pigtail.
Neet Injector Trick Yahiko 6.0L Power Stroke Diesel 12 12-30-2014 06:12 PM
Ebay junk to avoid IMHO Yahiko 6.0L Power Stroke Diesel 4 10-07-2014 07:29 PM
Upgraded water pump from Alliant Power (2010) bismic 6.0L Power Stroke Diesel 3 08-26-2013 12:07 PM
Oil filter standpipe damage pics from FDDTS bismic 6.0L Power Stroke Diesel 4 08-25-2013 11:13 PM
Anyone need the HP oil rail to injector O-ring??? matty169 6.0L Power Stroke Diesel 3 04-19-2010 07:23 AM
Tags
777
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
