Fuse 5 underhood blowing and no Cruise Control - Ford Truck Enthusiasts Forums
Old 07-14-2014, 12:03 AM
tractoman's Avatar
tractoman tractoman is offline
tractoman is starting off with a positive reputation.
Gents cruise stopped working suddenly. Brake lights all good, switch on the master is N/C and I do have the recall harness which has good continuity. While looking into the cruise issue, I found fuse 5 under the hood blown. This is for DRL's which I don't have, or even a harness that I can find, back up lights that are obviously not working, it energizes the trailer charge relay, and powers the trans digital position sensor. Could the tps cause a short and what symptoms would I experience if this was the problem. Also could this cause the cruise not to work if the PCM is getting poor info? What else could cause this fuse 5 to blow constantly? I have not been doing any wiring or even been under the truck for awhile. This is a California model PSD.
Old 07-14-2014, 08:35 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
subscribing, IDK but this will give you a bump!
Old 07-14-2014, 09:16 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Underhood fuse #5 (fuse E) also powers the redundant switch on the master cylinder (where the recall was done). Open circuit there tells the PCM not to engage the cruise.
Old 07-14-2014, 11:21 AM
tractoman's Avatar
I have a closed circuit on the switch at the master tested at the switch and through the add on harness. I will check out the bulbs tonight. Is the TRS where the switch is for the back up lamps?
Old 07-14-2014, 11:44 AM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
The trans range selector switch is where reverse is, that can cause a short, so can the reverse lights, I had a problem on my 99 and turnout to be the clock spring.
Old 07-14-2014, 11:21 PM
tractoman's Avatar
Just a quick update. Checked back up light wiring and found a short. Checked the TRS and had power there and with the harness disconnected still a dead short to the back up lights. Finally decided to check the in bed 7 pin trailer connecter and found the ground wire had come loose off its terminal and was causing the short. Fixed this and it's all good now. Haven't tried the cruise yet but back up lights are good and I am pretty certain I am back in business. Lesson of the day? Check the easy stuff first.
speedometer cruise control not working 67aj 1987 - 1996 F150 & Larger F-Series Trucks 2 12-24-2016 08:34 PM
Cruise control not working Cummins7mm 1987 - 1996 F150 & Larger F-Series Trucks 0 04-22-2016 12:07 PM
Cruise control problem, pressure switch bypass Pipeliner_86 Excursion - King of SUVs 8 12-03-2015 08:01 AM
Cruise deactivation switch harness fuse? sccamper Excursion - King of SUVs 10 12-23-2013 09:32 PM
Brake position switch Plowboy34 Ranger & B-Series 13 12-05-2013 05:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
