2 Issues 2014 f-250 (Sirius and front end noise)
So I have had my 2014 since late February and it now has 5500 miles on it. So on the next trip to the dealer, unless there is some answers here, I am going to have them check the following:
Sirius has no audio after turning the truck off and then coming back say 15 minutes to and hour later and starting up again. Turning the off the unit and turning back on gets the audio back, switching source does not seem to get the audio from Sirius back, although FM is fine when you select that source. This is intermittent. The software is up to date, but I have not done a reset.
Turning to the right and braking steep downhill under 30mph causes a noise and maybe a vibration in the brake pedal almost like ABS, might even be ABS. I only notice it on this one road very close to my house which I go on every time I go out. It doesn't seem to do it anywhere else.
Try same curve with your advancetrac disabled
No idea on the radio but the braking and turning could be an issue with your advancetrac, typically I have noticed mine activate around corners on gravel roads although I usually disable advancetrac with a several second press of the traction control button... try that and see if it sounds the same. Extra information when you go in for service will help them narrow it down.
ref: "Sirius has no audio after turning the truck off and then coming back say 15 minutes to and hour later and starting up again. Turning the off the unit and turning back on gets the audio back, switching source does not seem to get the audio from Sirius back, although FM is fine when you select that source. This is intermittent. The software is up to date, but I have not done a reset."
I have the exact problem with my 2014 F250 Sirius Audio, did you solve the problem and how?
