Truck pooped out. - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Truck pooped out.
Old 07-13-2014, 09:26 PM
jeepnford jeepnford is offline
jeepnford is starting off with a positive reputation.
Truck pooped out.
Well this bites. We were 45 miles from home pulling our fiver to Tennessee for vacation. I didn't buy gas before leaving so I pulled into a gas station and put in about 25 gallons. I made it about 50 feet and the thing wouldn't go above a very rough idle. I see the obvious possibility of bad gas but it seems strange I didn't make it out of the parking lot before it all went south. I was given the opportunity of a lifetime to watch people buy gas for a couple of hours waiting on a tow and they all made it out fine. Needless to say the vacation is toast but look at all the money I've saved. If it is indeed bad fuel there will be the upcoming heavy-weight championship fight with the gas station. Anyway, does someone have any other ideas on what it might be?
Old 07-14-2014, 02:53 PM
albertatyke albertatyke is offline
albertatyke is starting off with a positive reputation.
I've just had my fuel pump replaced, I don't know if it's relevant to your truck, because mine ran, but it was very rough and wouldn't really pull more than 3500rpms no matter how much I pushed the throttle.
Old 07-14-2014, 03:44 PM
This is great. I just talked to the dealer and got the "we can't find anything wrong." I guess me, my wife, tow truck driver, and a couple of good Samaritans were all imagining this. Should have kept my 01 diesel. Now I own a $45,000 casino. Place your bets on when this will happen again.
Old 07-14-2014, 04:37 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is online now
ATP Pilot is gaining momentum as a positive member of FTE.
maybe you had a little water that worked its way out, or vapor lock...if this can even happen on this type of fuel system.
No stored codes in the computer??
Old 07-14-2014, 06:15 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
I think some Fords have little quirks sometimes. I was getting on the freeway with my 99 Ford Crown Vic & about 74 mph it started vibrating like a flat tire. As I pulled over the CEL started flashing. Got out check to see if the tires were OK. Got in the CEL was off & we drove off. That was two weeks & 2000 miles ago & it has been OK. We are on our third trip out of town all is good.
The big difference is my Crown Vic cost me $400.
But I have had other funny things happen that were just weird & only once.
It could of been anything & may never happen again. Maybe when you turned off the key it cleared. With computer vehicles I don't loose hope & call for help until I try a few times & the vehicle continues to act up.
Hope it was just a weird quirk.
Old 07-14-2014, 10:10 PM
No stored codes. If this happens again does disconnecting the battery for 15 or 20 minutes help reset the PCM any more?
Old 07-14-2014, 11:02 PM
kermmydog's Avatar
Smile
Quote:
YES. It will
Old 07-15-2014, 09:23 AM
kerm7807 kerm7807 is offline
kerm7807 is starting off with a positive reputation.
This may sound stupid, but we had all kinds of problems with a ford car a few years back. Same kind of thing that went on for months until we finally went lemon law and won. It ended up being the simplest stupidest thing in the end and the garage just over looked it the whole time. The fuel filter was plugged and it was a new car. We started having severe problems at around 8000 miles. Who would have thought it possible? The car would stall, run rough, buck and jerk. It was so frustrating and we loved the car. Just food for thought.
Old 07-18-2014, 06:03 PM
I just returned from a lesser distance trip than the original I had planned. Only went about 400 miles round trip and the truck ran fine pulling my 30 ft. fiver. During my initial trouble I tried shutting it off and restarting a few times but it made no difference so we shall see.
09 F150 Loss of Power on Acceleration FordGirl2009 2009 - 2014 F150 2 07-28-2015 04:07 PM
Today's project on my 16 yo fifth wheel clem1226 Fifth Wheel & Gooseneck RV Towing 8 07-27-2015 06:47 PM
66 F100 Custom twister1974 1961 - 1966 F-100 & Larger F-Series Trucks 7 02-13-2015 09:05 AM
2015 JANUARY Tennessee Everything Thread macgiobuin Tennessee Chapter 132 01-31-2015 08:48 PM
96 e 250 battery problems speedsean137 1968-2013 Full Size Vans 4 07-20-2014 07:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
