When to start towing - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 07-13-2014, 08:51 PM
ungaii102 ungaii102 is offline
ungaii102 is starting off with a positive reputation.
I have a 2015 F250 6.2 L with 300 miles on it. My question is do I need to put some break-in miles on it or just start towing. I have a 26 foot TT that weighs less than 6250 lbs loaded. thanks
Old 07-13-2014, 09:15 PM
Bandguy Bandguy is offline
Bandguy is gaining momentum as a positive member of FTE.
I think the book said 500. My dealer suggested at least 1,000 or more for the trans to go through the learning process.
Old 07-13-2014, 09:55 PM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to behold
I started at 370 miles pulling our 16K 5ver, I did take it easy for a while and it never heated up or acted like it was having any problems. After about 5K it really can alive. I've always been in the break it in the way your going to use it crowd.
Denny
Old 07-14-2014, 09:53 AM
Big Vic Big Vic is offline
Big Vic is starting off with a positive reputation.
My 2014 manual states 1000 miles. I did my first tow then-now that I have about 2600 miles I note that the truck is towing better than at 1000. Not sure why, but as others have pointed out, it takes awhile for the truck to break in and reach its max performance.
Old 07-14-2014, 02:36 PM
rayk1 rayk1 is offline
rayk1 is starting off with a positive reputation.
I managed to put about 700 miles on my 2013 before heading out on an 800 mile trip pulling 11K 5th wheel. Truck now has 6k on it and it really does a good job. Like Denny says "drive like you stole it".
Old 07-14-2014, 03:00 PM
BossGasser BossGasser is offline
BossGasser is gaining momentum as a positive member of FTE.BossGasser is gaining momentum as a positive member of FTE.
I drove 1000 miles solo.
Old 07-14-2014, 04:08 PM
T diesel T diesel is online now
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
1000 here as well.
Old 07-14-2014, 05:59 PM
Powelligator's Avatar
Powelligator Powelligator is offline
Powelligator is starting off with a positive reputation.
The first 450 miles were around town city miles, no long highway runs. After that I loaded the slide-in and put it to work. No ill effects, truck has about 9K now.
Old 07-14-2014, 06:46 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
Smile
Quote:
Denny
Every vehicle I ever bought new I followed that belief. I found that every vehicle got the best mileage the way it was broke in & performed the best that way also.
The old saying use to be that if it is going to blow let it do it on Fords dime, not mine.
I agree with giving it a few hundred miles but after that all bets are off. Every engine or tranny I ever rebuilt got that same treatment. The only difference was I would vary my speeds & pull on the rebuilt engines for a good 500 miles to seat the rings. But that never meant babying it.
Old 11-08-2014, 09:04 AM
Super Dan-o Super Dan-o is offline
Super Dan-o is starting off with a positive reputation.
I picked up my truck with 14mi, put a couple hundred on it unloaded that day and then hooked my 8k construction trailer up the next morning.
Nearing 1k miles now and it's been caned every step of the way and is breaking in nicely.
Old 11-08-2014, 08:27 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
The manual says 500 miles, but I waited until about 1000.
The purpose is not for engine or tranny break-in, but for the ring and pinion gears. It's important to let them set in without getting to hot...which towing does increase the temp of the gears.
Hope this helps...
biz
Towing a heavy load hhowell1990 2015+ F150 23 02-20-2016 12:00 AM
Tow with uhaul an tow bar Shenna Tipton Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 5 09-22-2015 01:19 AM
F350 Transmission Whine caseyodell 6.0L Power Stroke Diesel 11 07-07-2015 04:29 PM
322 miles Dascro58 6.7L Power Stroke Diesel 1 07-01-2015 09:31 AM
Weird turbo sound while towing 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 3 06-18-2014 11:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
