1966 ford overheating issues...
My 66' has a 351w in it( 74'-79' model). It's been running great with no issues. Then the other day it started to over heat. Temp would get to around 220-230 then go back down to 185-190 and back up to 220 or so, kept going back and forth. I changed out the thermostat and the same thing happened. So, I replaced the water pump and Radiator(cause I accidently put a nice hole in the radiator taking it out)....
So, New thermostat, new radiator and new water pump. still runs hot just idling(no running up and down the road). The old brittle shroud broke and I have yet to replace it. I did remove the new thermostat and that made no changes to the rising temp.
Any ideas on why all of a sudden my truck decides to run hot? Can a new shroud really make all the difference? I would think even without the shroud it would not run hot just idling... but I'm novice mechanic. The guy at the parts house measured my Radiator and sold me one the same size that fits a 79' ford truck which matched mine "almost" identically.
Any help is appreciated.
Thanks,
David
Thanks,
David
I often wondered why they put those stainless steal coils in the lower (suction side) radiator hose years ago.
I guess it had nothing to do with hose collapsing. But I bet it helped when they got older. If they weren't corroded away.
But I have seen hoses collapse.
David, I have been around these trucks since they were new, they have a few ideos that you have to deal with one way or another.
You can not fill the gas tank and park it out without the sun heating and expanding the gas causing it to run out the filler. You have to not let the rubber hose between the tank & filler dry rot or gas will stink up the cab. You can not let these ol boys sit and idle in the hot temps, without them overheating. You can either keep them moving forward, idle them up, or shut them off. Leave at least 2-3" of air space in the top of the radiator or it will boil it out to get it. The system has about 4.5 gallons in it so a cup or two at the top is alright.
You can also spend money on shrouds, fans and other items or be the manager of the truck.
John
John
If the water level remains constant, suggest pull dipstick for cloudy oil. Also check fan belt alignment and tension. A faulty radiator cap (not holding pressure) can cause engine overheat. The water to anti freeze may be too rich, believe should not be over 50/50. And then there's the timing?? Fan shroud is handy but should not be the cause for over heating. Anyhow, couple suggestions of food for thought?
My '66 has a 351w in it ('74-'79 model). It's been running great with no issues. Then the other day it started to over heat. Temp would get to around 220-230 then go back down to 185-190 and back up to 220 or so, kept going back and forth. I changed out the thermostat and the same thing happened. So, I replaced the water pump and Radiator (cause I accidently put a nice hole in the radiator taking it out)....
So, New thermostat, new radiator and new water pump. still runs hot just idling (no running up and down the road).
If it's a FoMoCo shroud, will have an ID engineering number marked on the upper left corner.
The following shroud will bolt on without any mods: D3TZ-8146-C (replaced C8TZ-8146-K), marked on upper left corner: C8TA-8146-S or D3TA-8146-DA
Original applications: 1968/76 F100/350 360/390 with standard, xtra cooling & A/C radiators. NOT used with Super Cooling radiator.
Reproduced by Dennis Carpenter.
Thanks for all the replies guys,
Rusbukt, New hoses all the way around.
87Bronco, Yes it's a mechanical fan. And YES I do have an aftermarket temp/amp/oil guage on it. It's an old sunpro unit. Likely installed when the motor was put in. Seems to work well.
Jowilker, I definitely need to replace those short little rubber hoses on the gas tank inside the truck.
Dave, Water level remains constant, No cloudy oil. Fan belt and alignment are correct.
Number Dummy, There IS a part number on the lower left side. D2-TA-8146-FA.... I'll check it out. There is a 4 inch thin metal plate than runs down the entire length of one side. It allows the shroud to be offset. I was hoping maybe I could find a unit that would discontinue that plate.
Thanks again guys and i'll keep you updated..
Oh. I sprung a hinge on my hood yesterday... UGH! I knew it was going bad.
This is a fan shroud for a 1971/72 F100 302 with Standard Cooling.
Since the ID engineering number for ALL fan shrouds is located at the upper left (drivers side) corner, someone rotated it so it would fit.
Thanks for all the info guys... I used some stuff called "Plastic Welder" to fix my fan. That stuff works pretty darn good. Got the fan back on and all is ok. Ran the truck for about 15 minutes and it never got above 110. Guess I can go ahead and put my thermostat back in I would never have believed a shroud could make that much difference. I'll be keeping an eye out for a new fan. But for now, I'm ok. Well.... accept for the hood hinge that sprung and broke on me yesterday!! UGH!!
Ps, Numberdummy, This one on ebay Would work with my metal extension....but a little pricey-
71 72 F100 302 w Standard Cooling RARE Ford D1TZ 8146 E Shroud Fan | eBay
This one would work. But I would have to turn it upside down. No extension needed.
Thoughts???
Ford Fan Shroud - D3TZ-8146-C - C&G Ford Parts
Thoughts???
Waaay overpriced!
Ford Fan Shroud - D3TZ-8146-C - C&G Ford Parts located in Escondido CA
Waaay overpriced!
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
D3TZ-8146-C is reproduced by Carpenter, many other repro parts sellers also have it.
I see no reason to buy it from a supplier in SoCal (Escondido is 30 miles north of San Diego), then pay extra shipping charges to MS since it's available in NC
