Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers & 5th Wheels
Sign in using an external account
Register Forgot Password?
Towing, Trailers & 5th Wheels SPONSORED BY:
Towing with a F250
Old 07-13-2014, 05:24 PM
dvadushni dvadushni is offline
dvadushni is starting off with a positive reputation.
Towing with a F250
I just wanted to get some opinions on towing with a 3v 5.4. It is a 2005 F250 short bed with the 3.73L in the rear single axle. The trailer in question is a 11k unloaded 14K max fifth wheel. Im only looking to tow it for about 70 miles back and forth once.
Old 07-13-2014, 07:34 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
According to trailer life magazine. You are maxed out at 11K. So you wouldn't be able to load anything in the truck or trailer. Sorry.
You have a max gcwr of 18K
__________________
red 04 F250 build date 04/04 6.0 PSD
2013 gulfstream canyon trail fifth wheel Aztec edition 40 ft
Vietnam Vet/ OS1 USN/USNR retired 26 years
Old 07-13-2014, 10:14 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant future
Quote:
With only towing that far once you will be fine, Just keep it as light as possible, My fifth is 10,000 and I tow it all across the country..
__________________
Chris aka FTEMaB 3
2003 F250 fx4 cc short box. 5.4 , 4.30 gears, flowmaster 50 , spd Y pipe , eagle alloys , 285/70/17 nitto terra grapplers, SCT X3 tuned , warn manual hubs, 6.0 trans cooler mod
2006 Keystone sprinter copper canyon
2000 f150 4x4 work truck 4.6 AKA Martha
http://i1206.photobucket.com/albums/...es35/truck.jpg
Old 07-13-2014, 10:15 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
no matter what as bigred said, you'll be really straining,
but more so in the mountains than on the flats ...
__________________
People are much more opposed to fur than leather because it's much easier to harass rich women than motorcycle gangs.
13 F350 Platinum 6.7 CCSB being chased by 14 Redwood 38GK 5er, 13 Explorer Sport 3.5 Twin Turbo 365 hp Ecoboost. Gone: 12 MVP Destiny 355RE 5er,12 F250 6.7 CCSB Grey Metallic Lariat w/ Ultimate Pkg,05 Ex 4x4 6L,03 Ex 4x4 6L,02 Ex 4x2 7.3L
Old 07-13-2014, 10:32 PM
wingedone's Avatar
wingedone wingedone is offline
wingedone has a good reputation on FTE.wingedone has a good reputation on FTE.wingedone has a good reputation on FTE.
Only towing it twice, ever? Then fine. Keep towing it, overloading the truck, don't say we didn't warn you. Take it slowwwwwwwwwwww.
__________________
Thomas
2013 F350 DRW 6.7 Lariat, Kodiak/Adobe.
2011 Brookstone 354TS, SwivelWheel 58dw, 1993 Goldwing SE
Old 07-14-2014, 01:52 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Hopefully you have the trailer tow package from the factory on the truck. You won't have a problem going slow...that engine won't let you go too fast!
Slowing down may be a problem tho.... take it easy and anticipate your stopping and you should be ok only going 140 miles once. Do it in the daylight.... your headlight might be aimed into the trees at night.
__________________
BPofMD - Bud - USN-Actively Retired
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/Mishimoto T-stat
2007 Arctic Fox 30' Fifth Wheel
2012 VW Passat SE TDI - SG-II (An ALL-DIESEL family)
Old 07-14-2014, 02:09 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Do you the trailer brake controller and tow mirrors? If so then I would do it twice..but no more than that as you will really have to pay attention.
__________________
Scott-2013 F350 with a lot of tires.
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400; 2015 Lincoln MKC
http://www.ford-trucks.com/guidelines.html
Previous Truck 2008 F250 6.4 with lots of upgrades and a suspension upgrade from Torklift International StableLoads
Old 07-14-2014, 03:44 PM
Why will he have anymore problem slowing down with his truck than you do with yours? They are the exact same axles,brakes,and trans as yours..
__________________
Chris aka FTEMaB 3
Old 07-14-2014, 04:19 PM
BPofMD's Avatar
Posting Legend
No he doesn't .... he won't have the Tow/Haul mode.... doesn't have a diesel nor the trailer tow package. Doubt if he has the Tow Command module in his either.
__________________
Old 07-14-2014, 05:23 PM
He does to have the tow/haul mode all the 3V gas motors do, and he never posted anything about not having the trailer tow package..The only thing he will be lacking is the get up and go that the diesels have other than that its the same...
__________________
Chris aka FTEMaB 3
Old 07-14-2014, 05:59 PM
BPofMD's Avatar
Posting Legend
OK...we don't have all the facts... I still say to tow it cautiously, but do the 2-way trip. Hopefully he has some kind of trailer braking system installed.
__________________
Old 07-14-2014, 09:15 PM
Totally agree..
__________________
Chris aka FTEMaB 3
Similar Threads
First 2010 oil change F250nube Super Duty & Heavy Duty 7 05-12-2010 06:52 PM
Towing capacity of 01 F250 ktplotts 1999 - 2003 7.3L Power Stroke Diesel 13 06-22-2005 03:19 PM
does anyone actually tow 8k+ with the expy? henryr Expedition & Navigator 18 04-15-2005 09:09 AM
Tow More with F15o ClydeDriver 1997 - 2003 F150 11 09-29-2003 10:59 AM
F-250-f-350 bronczilla Super Duty & Heavy Duty 2 05-29-2003 12:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
