Anyone make their own headliner? - Ford Truck Enthusiasts Forums
Old 07-13-2014, 01:32 PM
79F250isalive! 79F250isalive! is offline
79F250isalive! is starting off with a positive reputation.
The headliner in my 79 F250 custom had seen better days and was falling apart so I took it out. Anyone ever make their own headliner? What material did you use? Did you cover it with anything? I am thinking of finding something to use as the base and then covering it with amp tolex. I play guitar and have re covered numerous amps with tolex. It is pretty simple to work with and doesn't cost much.
Also, the middle brace is bent down. I noticed that there was a dip in my headliner in the middle. I don't recall this. I thought they were pretty much straight across the top so I am thinking I need to bend that brace up towards the roof to straighten in out.
Old 07-13-2014, 01:40 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Old 07-13-2014, 01:41 PM
dustyroad's Avatar
dustyroad dustyroad is offline
dustyroad is gaining momentum as a positive member of FTE.dustyroad is gaining momentum as a positive member of FTE.
Old 07-13-2014, 03:54 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
One more time just to be redundant and repetitive!
http://www.ford-trucks.com/forums/10...the-cheap.html
Old 07-13-2014, 04:56 PM
co425's Avatar
Old 07-13-2014, 05:07 PM
406angler's Avatar
406angler 406angler is offline
406angler is starting off with a positive reputation.
Yep! and re-did my door panels; it's retardedly easy. 1.5yds whatever fabric you want (that WON'T sun-FADE), a good upholstry spray-adhesive or contact cement; cut to shape, apply adhesive, roll on fabric, let dry, reinstall on truck. I did my doors and headliner in RealtreeAP.
Old 07-13-2014, 05:18 PM
co425's Avatar
Quote:
Pictures, please.
Old 07-13-2014, 07:15 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Where's that thread about using the US flag as a headliner? That turned into a pretty big p*ssing contest
CO: really nice work. You've got one of the nicest interiors on the forum IMO.
Old 07-13-2014, 07:57 PM
co425's Avatar
Thanks, appreciate it.
Old 07-13-2014, 08:32 PM
406angler's Avatar
If you've been in the military, or served as an Honor Guardsman in the military (go FAR deeper into customs/courtesys, proper display, folding etc...) you'd be pretty irritated to see the flag as a headliner; but, it's your right as an american. See below:
176. Respect for flag
No disrespect should be shown to the flag of the United States of America
(c) The flag should never be carried flat or horizontally, but always aloft and free
(d) The flag should never be used as wearing apparel, bedding, or drapery. It should never be festooned, drawn back, nor up, in folds, but always allowed to fall free.
(e) The flag should never be fastened, displayed, used, or stored in such a manner as to permit it to be easily torn, soiled, or damaged in any way.
(f) The flag should never be used as a covering for a ceiling.
Reference: US Flag Code
fmc400, that was in NO way directed towards you, I read that post you're referring to and wasn't a fan of the idea of using it as a headliner. [500 pushups per infraction of the flag drives stuff like that into your head pretty quick] :P
Old 07-13-2014, 08:35 PM
406angler's Avatar
Quote:
Originally Posted by co425 View Post
Pictures, please.
Absolutely, I'll try to dig a few of them up after work; I think it turned out well and hasn't faded a bit!
Old 07-13-2014, 08:42 PM
FordIowan FordIowan is offline
FordIowan is starting off with a positive reputation.
I bought a sheet of 3/16" hardboard at the local lumberyard. Put the old headliner over it and traced out the pattern. Cut with a jigsaw then went to JoAnn Fabrics and bought a piece of vinyl that was a close color match to my interior. I used spray adhesive to glue the vinyl to the hardboard and installed back in my truck. The most expensive part was the vinyl, but it was still done for about 40 bucks and looked better that the old cardboard headliner.
Old 07-13-2014, 09:09 PM
fmc400's Avatar
MSEE
No worries at all; and I completely get it. I just thought it was an interesting thread. And, thank you for your service good sir!
Old 07-13-2014, 10:27 PM
82GT's Avatar
82GT 82GT is offline
82GT is starting off with a positive reputation.
I glued foam on the original headliner and wrapped it in pleather. tuffed it with some brass buttons
Old 07-13-2014, 11:30 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Hope you did NOT use the 3M spray, total waste of money IMO. There is some good stuff in the other head liner links spray wise.
headliner support bar 79F250isalive! 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-16-2014 11:46 PM
65 Headliner - Make It Look Custom For $25 taylorjgreen 1961 - 1966 F-100 & Larger F-Series Trucks 16 02-12-2013 10:02 PM
FRP Headliner Step By Step davewave649 1961 - 1966 F-100 & Larger F-Series Trucks 11 08-20-2012 12:56 PM
Can you show me your headliner larryb346 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-26-2011 03:16 PM
Headliner phubble 1973 - 1979 F-100 & Larger F-Series Trucks 17 03-13-2010 09:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
