Build Sheet: International Water Pump - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-13-2014, 01:07 PM
redman84's Avatar
redman84 redman84 is online now
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
My water pump has been weeping for a while now so I finally did the IH pump install. So far so good. I really like the fact that it helps clean up the engine bay somewhat as opposed to cluttering it more. There are positives and negatives to doing this pump vs the bypass filter and vice versa. They've been discussed on here several times. I decided from those discussions that the pump itself is what I wanted. I also took the opportunity to replace the coolant recovery tank, thermostat, thermostat housing, and swap the fan blade for a 6.0L fan. There are several how to's running around so this is just my build sheet and a few pics. I'll report back in the future with any pertinent findings. Hopefully it helps someone.
No more heater hose running across the top of the alternator.
Looking down. I decided to paint it "Ford gray". Did the reinforcement ring on the tstat housing and the FPR supports too. It's hard to match a color to the toreador red so I figured gray was as good as any.
Looking up. Plenty of room to get at the filter and shutoff valve.
Another looking down. The 6.0 fan fits nicely. Not sure if it is me or reality but it seems to really hum when the engine is revved.
The final build sheet
Old 07-13-2014, 02:46 PM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
Thanks for the pictures and information. I look forward to your updates. Reps sent.
Old 07-13-2014, 07:48 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Good job Jacob!
Old 07-14-2014, 01:26 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
I didn't know the tank was still available. Thanks for the pics.
OBS supercab front bench redman84 Ford Truck Parts for Sale 1 08-15-2014 11:36 AM
I need a driveshaft measurement redman84 1994.5 - 1997 7.3L Power Stroke Diesel 14 01-08-2014 11:58 AM
Keyless Entry with Engine Running redman84 1994.5 - 1997 7.3L Power Stroke Diesel 16 12-20-2013 08:48 AM
Mods, Maintenance, and Life(long and kind of pic heavy) redman84 1994.5 - 1997 7.3L Power Stroke Diesel 17 05-29-2013 01:38 PM
Doing oil cooler. How does this go back in? redman84 1994.5 - 1997 7.3L Power Stroke Diesel 9 04-23-2012 09:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
