'99 SD Tailgate Latch/Lock Problem
Hello everyone,
Since I received some great advice on my last Power Stroke repair issue, here's another for you...
After much searching I was able to locate an acceptable replacement tailgate for my '99 F-250 long bed (the original tailgate was banged up several years ago; I salvaged the lock cylinder out of it prior to disposal).
The replacement tailgate is from a '99 F-150, but everyone said that they're interchangeable, which seems to be the case.
The latch handle that came with it didn't have the lock option, so I had to obtain an OEM latch handle that would accept my original tailgate's lock cylinder (matched locks all around).
Then, I found out that I needed the plastic, slotted insert/sleeve that fits in the right-hand hinge "cup" of the tailgate, that the slotted tongue on the right-hand side of the truck bed slips into, when installing the tailgate. Luckily, the local Ford dealership's parts dept was a source for one of these. It came with a shim washer which I went ahead and placed behind the plastic, slotted insert/sleeve, when I snapped it into the cup hinge of the tailgate.
So, I've installed the lock cylinder and latch handle in the new ("recycled") tailgate, and have the tailgate on the back of the truck.
But, here's the problem:
I can't seem to lock the tailgate.
There's a lever arm off the rear of the lock cylinder that doesn't engage any of the latch mechanism within the tailgate (see photo, below).
What I don't understand is, how does the lock work, and is there a need to adjust the tailgate (shim/no shim, adjust latch rods, etc)?
'99 SD Tailgate Latch Mechanism with Lock Cylinder.
The first time I tried the lock, the tailgate latch handle would always open the tailgate easily. Then, I removed the latch handle assembly from the tailgate and reinstalled it, only to find that I could only get the tailgate open when I stood up on the rear bumper and lifted up on the latch handle, apparently lifting the tailgate slightly, allowing it to unlatch and swing open.
So, either way, it still appears that the lock doesn't function.
And, again, I can't figure out how the lock interfaces with the latch mechanism within the tailgate, allowing it to lock and unlock.
Naturally, I'm doing all this without a service manual, and I don't have the original tailgate to use as a reference...
Any advice on how the lock functions, and how to adjust the tailgate's latch mechansim, if necessary, would be greatly appreciated.
Thanks,
1999er
Thanks,
1999er
You might try an online ford parts store to see if their catalog has pics ???
http://parts.autonationfordwhitebearlake.com/auto-parts
Maybe some of these links will help ?
https://www.google.com/search?q=1999...x-a&channel=sb
or youtube :
https://www.youtube.com/results?sear...ock+replacment
good luck !
or youtube :
good luck !
The online Ford parts diagrams didn't have enough detail to help me (but thanks for the suggestion).
Also, I've investigated the Pop & Lock add-on lock, but don't understand how it functions either. I'm so close to solving this with the components I already have, and don't want to backtrack.
I think Rockcrusher 24's comment about a missing triangular piece is my next idea to pursue.
Thanks, guys!
(I wish I could have held on to the old tailgate... for reference and small parts.)
Success!!!
I went to the Ford parts dept and was able to determine that there are two diffent tailgate latch control assemblies. Here's a photo of them:
These are the latch control assemblies that interface with the rods that operate the latches on both sides of the tailgate. The one on the left is the one that came with the non-lockable tailgate, and the one I replaced it with, that interfaces with the lock cylinder, is on the right. Note the black plastic triangular piece. The level arm on the rear of the lock cylinder fits within the open area of this triangular piece.
Thanks for everyone's assistance.
Regards,
1999er
hl8a
1999 to 2016 Super Duty
03-06-2016 07:16 AM
