ZF6 Swap questions? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
ZF6 Swap questions?
Old 07-13-2014, 10:49 AM
marcomjl marcomjl is offline
marcomjl is starting off with a positive reputation.
ZF6 Swap questions?
Hi,
I have a 2000 F450 with auto. I am interested in a swap and will be looking for someone who wants to swap into an auto to make it easier. I wanted to know if the zf6 of the same years 99-03 7.3 units are the same on F350s/f450s with just a different clutch or are the units different?
Old 07-15-2014, 08:49 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Yes. Well, the service manual lists two different models of ZF-6, but it only lists a single set of part numbers, so I wouldn't have the foggiest on how to tell them apart.
As far as I know the clutch is the same as well.
Trans swap arkredneck 1994.5 - 1997 7.3L Power Stroke Diesel 0 10-25-2015 06:36 PM
450 transmission swap Belair_nova 1999 to 2016 Super Duty 0 07-29-2015 03:12 PM
manual swap DMAN 1999 to 2016 Super Duty 1 02-14-2015 04:45 PM
ZF6 2wd to 4wd 86fu50 1999 - 2003 7.3L Power Stroke Diesel 3 05-25-2007 11:49 PM
ZF 5 speed swap-78 F250 4x4, 460/C-6 4byford Clutch, Transmission, Differential, Axle & Transfer Case 5 12-30-2003 06:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
