Awful transmission clunk from Park - Ford Truck Enthusiasts Forums
Old 07-13-2014, 07:30 AM
WhlM1's Avatar
WhlM1 WhlM1 is offline
WhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant future
... it clunks real bad at random times. Whether I have had the e-brake on or not (sometimes even with it on, so I have not put any load on the locking mechanism in the tranny).
Its a 2014... anyone else get this? Does not matter if its inclined ground or flat.
Sucks that it does this for the extreme amounts of money they charge. My 08 F350 V10 it replaces never once clunked.
Old 07-13-2014, 08:15 AM
Averill7's Avatar
Averill7 Averill7 is offline
Averill7 is gaining momentum as a positive member of FTE.
My guess would be to take in to a dealership and have them take a look at the shift solenoids. My 2011 did this several years ago and they found several faulty shift solenoids. After the fix, all the gears shifted better and the reverse clunk was gone and hasn't come back in 30 - 40k miles.
Old 07-13-2014, 08:23 AM
Big-Foot's Avatar
Big-Foot Big-Foot is online now
Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
When was the last time the slip joint in the driveshaft was lubricated?
When you stop the truck and set the parking brake, put it in neutral first, then set the brake, then shift into park. This will leave the transmission totally unloaded and there should be very little if any tension ob the park pawl.
Old 07-13-2014, 11:48 AM
Glittle's Avatar
Glittle Glittle is offline
Glittle is starting off with a positive reputation.
My 12 did this real bad and my 14 does it too. Really annoying to have a $60K truck that clunks so loud that people look to see if you just hit something. It does it on flat ground and is really bad when on an incline. Using the neutral first method on flat ground helps some, but doesn't cure it 100%. On an incline, neutral, parking brake as hard as possible, and then into park helps some. I don't feel like I should have to do this, but I don't think there is a fix...
Old 07-13-2014, 03:10 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Does it do it if you engage the e-brake first?
If you put it in park, apply the e-brake and then release the service brake, it still moves slightly and the parking pawl seems to take some of the load.
My 2011 does this so I learned if I always shift to neutral, apply e-brake, release service brake so the e-brake takes the load and then shift to park, it prevents that awful clunk. Even this process is quick.
Mine will clunk if the e-brake doesn't have the load first.
Old 07-13-2014, 03:18 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Sounds like the slip joint to me. That's the easiest and cheapest thing to address before going any further. While the drive shaft is apart you can also check your u joints.
Old 07-14-2014, 08:43 AM
Glittle's Avatar
I use the neutral, e-brake, shift to park method to lessen the chance of the clunk. I just don't think I should have to fumble around with shifting to neutral every time I want to park the truck.
Old 07-14-2014, 08:44 AM
Glittle's Avatar
Quote:
Trucks do it brand new off the lot. It seems as if the driveline is bound up when shifting from park to reverse or drive.
Old 07-14-2014, 09:23 AM
WhlM1's Avatar
It is not a slipjoint... absolutely in the tranny. Almost tough to shift from P out, and you can feel it in the shifter.
Only 5k miles on it, so it should not be doing this...
Does it more with the e-brake being used, which is the weirdest part. Gonna have the first oil change done soon and tell them to look at it. For the money, it should be perfect.
Old 07-14-2014, 09:40 AM
Glittle's Avatar
Please post back what they tell you. I'm interested before I waste my time with the dealer myself.
Old 07-14-2014, 11:53 AM
FordService's Avatar
FordService FordService is offline
Official Ford Rep
FordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud of
... Gonna have the first oil change done soon and tell them to look at it...
Good idea, WhlM1. Send me a PM when you're ready to head into the dealership and I'll loop in your regional customer service manager. When writing, please include your full name, best daytime phone number, VIN, current mileage, and servicing dealership.
Crystal
Old 07-14-2014, 07:29 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
Likewise, mine makes the same noise too. Let us know what the dealer says Rich!
Old 08-12-2014, 10:03 AM
Glittle's Avatar
Rich - Resurrecting an old one to see what the dealer told you. I am thinking of taking mine in if they have a solution to fix the clunking.
Old 08-13-2014, 11:28 PM
2015F350 2015F350 is offline
2015F350 is gaining momentum as a positive member of FTE.
Quote:
Hi Everyone,
I have this same issue with my 2015 F350. When I shift from park to drive it makes a clunk sound and feels like the brake is holding the truck(Only does it on an incline). Then it will surge forward. Had it towed to the dealer because I didn't want to damage anything further. I Felt stupid when the dealer told me they could find nothing wrong. They said it is Normal to pause before engaging into drive. They said it has a hill assist to keep the truck from rolling back when going from the brake to the gas pedal. To me seems to long or I'm too fast. Anyway I'm not satisfied with the way it is so I'm going to check another dealer.
Old 08-14-2014, 12:36 AM
Mark Von Achen's Avatar
Mark Von Achen Mark Von Achen is offline
Mark Von Achen is starting off with a positive reputation.
ive been having the same issue, i will try this tomorrow thx
F250 clunk clunk noise eberlestock 6.2L V8 3 11-18-2015 02:32 PM
Frontend Clunk FordTruckChuck 1997 - 2003 F150 6 02-09-2015 01:41 AM
Clunk VS Wobble ves83 6.0L Power Stroke Diesel 3 09-25-2014 10:08 AM
Front End Clunk Walleye Hunter 1999 - 2003 7.3L Power Stroke Diesel 11 06-01-2014 04:41 AM
Brake Clunk Blafferty General Automotive Discussion 4 11-30-2009 02:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
