headers and engine swap - Ford Truck Enthusiasts Forums
Old 07-12-2014, 10:12 PM
99rangerdan 99rangerdan is offline
99rangerdan is starting off with a positive reputation.
I am putting a 4.6 out of a 95 crown police in my 67 f100 I am looking to put headers on it but am not sure about the flange some look like the bolt location moves and do I need the egr or can I eliminate it I am shaping the whole harness and Trans as well any help would be great thanks
Old 07-24-2014, 03:19 PM
badranger34's Avatar
badranger34 badranger34 is offline
badranger34 is starting off with a positive reputation.
Are you looking to purchase headers, or make your own? I believe all 4.6L engines use the same flange design. When I fabbed up headers for my 4.6 DOHC, I purchased some flanges off ebay.
As far as EGR, you can just block it off. I am doing the same thing with my swap, however I will be using a tuner to eliminate the EGR function as well; so my CEL doesnt come on.
Old 07-25-2014, 07:51 PM
I am looking at buying a set just need to check the clearance i have vs mustang or f150 to see which style will work best hoping someone has tried and had brand and or style suggestions thanks for the feed back
header question Marten 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-29-2015 03:37 PM
Yet another headers question alf15092 1987 - 1996 F150 & Larger F-Series Trucks 8 05-28-2015 07:08 PM
Headers Beedub109r 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-11-2015 07:54 PM
Which Headers for a 351 W and 58 F100 jenkinsj 1957 - 1960 F100 & Larger F-Series Trucks 1 01-11-2015 10:43 AM
header gaskets? 1999stroke 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-25-2014 05:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
