Way too much fuel!
Old 07-27-2014, 07:35 PM
cliff_mennenger's Avatar
cliff_mennenger
cliff_mennenger is offline
Originally Posted by tylerz71
New fuel pump and filter STILL same issue. Next week I will get a fuel pressure vacuum tester tool and see what my pressure is. If I didn't have all papers and original build sheet on the truck I'd scrap it at this point lol
Do you have a way to bypass the solenoid and crank the engine. make a short video or post some pics of what we're dealing with. Can we post video in the forums?
Take care.
  #62
Old 07-27-2014, 07:53 PM
tylerz71's Avatar
tylerz71
tylerz71 is offline
I guess I could take the wire off the distributor but afraid it could contribute to flooding the cylinders. I post off of my iPhone and have tried to post a pic before so wouldn't know how to post a video. Let me see on that.
  #63
Old 07-27-2014, 08:19 PM
cliff_mennenger
I wouldn't do it that way. Just jumper the starter solenoid. No ignition events or spark will occur the engine will just crank not fire. Google it....this is something you need to know for fuel pressure tests and cranking compression. You really don't want to pull the center coil wire. That's is hard on the primary ignition components. Did you get the fuel pressure tester?
  #64
Old 07-27-2014, 09:50 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Yes, I suggest YouTube to do it.
  #65
Old 07-27-2014, 10:10 PM
Oldgreen100's Avatar
Oldgreen100
Oldgreen100 is offline
Originally Posted by roadrash63
Great !
Not.
standingby
or maybe ill just put my old 2 barrel on
i know its good!
But it needs the plastic fast idle cam
356 cfm
Have you hosed it down with carb cleaner? I'm running out if ideas of what else it could be honestly.....wait, i just got an idea. But i need to google something.
BTW does anyone know how to start a new thread? I feel like a total idiot that I haven't figured this out yet.
  #66
Old 07-28-2014, 06:48 AM
roadrash63's Avatar
roadrash63
roadrash63 is offline
Hey
I rebuilt the carb.
and have rebuilt 10 or more successfully before, all different types.
to specifications.have taken apart 3 or 4 times to check and recheck everything.
swapped floats,new needle and seat new gas filter and sealed off
every i mean every vacuum connection ex dist.
all emissions removed or blocked.
carb base gaskets.
carb tight on manifold. And carb body screws
I really thought it was the fuel pump from other posts.
original pump.
  #67
Old 07-28-2014, 06:51 AM
roadrash63's Avatar
roadrash63
Oh yeah
i checked the timing too
everthing lines up.
  #68
Old 07-28-2014, 07:04 AM
roadrash63's Avatar
roadrash63
81 F100 4.9 1bbl carter yf. Truck ran great til I changed fuel filter it seems like. Then it started dumping fuel. We rebuilt the carb with a new accelerator pump and all the other small items in the kit. Took the time and thought it was done right. We did not set the float because it seemed to be in good position. New needle and seat. Reinstalled and now still getting way too much fuel. It's spitting it out of the tube on the top of the carb while I pump the throttle to get the truck to start. Took plugs out and cleaned them and cleared cylinders.
When I pinch off the fuel line the truck runs decent. I drove it around the yard like that.
Can you guys tell me what to try next? I am a paycheck away from chunking the carb and getting a reman for $200 off rock auto. I don't want this thing to wash my rings out.
hi
what do you mean "when I pinch off the fuel line" ?
fuel supply line ?
  #69
Old 07-28-2014, 07:23 AM
roadrash63's Avatar
roadrash63
ok
this is what happens to me.
I crank the engine using a remote starter key on.
im running fuel from a gas can to ensure good gas.
( stuff from the tank was yellow )
it will start and run if I keep the rpms up, for a min or two then it dies.
even if I keep the throttle open.
next it blows fuel vapor and drops out of the carb.
including onto the entire height of my windshield and apx 24" wide.
I have removed the top of the carb w/o taking it off the engine and the fuel bowl level is apx. half or just below.
I even took my spare float and put it there to see what the level is with it in there.
looked ok to me.
idle screw has no effect.
will not idle at all.
needle and seat new and clear.
my carb is a 79 yfa and my ign is dirt cheap HEI.
  #70
Old 07-28-2014, 07:31 AM
roadrash63's Avatar
roadrash63
Check the return line to the tank. Might be plugged or pinched shut. Fuel pumps put out volume not pressure. All good fuel pumps will create more volume than the engine needs to operate. The excess has to be returned to the tank or it will create sufficient pressure to lift the needle off the seat. That's why pinching the fuel supply line "fixes" the problem. Let us know how it turns out.
I have a mechanical pump.
no return line.
  #71
Old 07-28-2014, 08:20 AM
Oldgreen100
ok
looked ok to me.
The exact same scenario happened to me, except the fuel never hit my windshield. The hood was in the way.
All that extra fuel is making it run really rich. One more time, where exactly is the gas coming out of?
roadrash, I'm stumped. You said you had a 2bbl right? What happens if you put that on? Just curious. This guy says he got a new repro carb and it was still erupting.
  #72
Old 07-28-2014, 08:43 AM
tylerz71's Avatar
tylerz71
tylerz71 is offline
Yea cutting fuel supply, by which I determined it was receiving far too much fuel. Sounds like we have a very similar issue
  #73
Old 07-28-2014, 10:43 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
How to start a new thread?
Click on the 1980-1986 Bullnose F100, F150 & Larger F-Series Trucks forum. About midway of the page, there is a blue colored "button" for New Threads.
  #74
Old 07-28-2014, 11:06 AM
Oldgreen100
THANK YOU!!! it's taken me months to figure that out!!! This is for a different truck though. I have two (lucky guy i know).
  #75
Old 07-28-2014, 11:09 AM
roadrash63's Avatar
roadrash63
comes out of the top of the carb venturi.
I have a 2bbl ford 2100 ? that I rebuilt and was originally on my 1969 351w out of a cougar. Had it on my old f150...
never had a problem with it ran it for 5 years.
waiting on the adapter I got from amazon for 10.00 new.
should be here wed.
Quick Reply: Way too much fuel!
