Way too much fuel!
#47
aaahhh !
I was pulling hair out...there's not much left!
I checked rechecked float / metering rod etc.
I have the original fuel pump on my 85 f250 300-6.
how does it regulate the pressure ?
also my yfa doent have a check ball or the little black hose from the accelerator pump. works fine.
#49
i ve got the same problem Volcano Carb !
Take care.
#51
The pump has a spring that lifts the pumping diaphragm away from the actuator lever when there is a head pressure created by pumping against the needle and seat. The pump doesn't really regulate the pressure it just doesn't pump. Do you have gasoline present in the crankcase oil?
Take care.
Take care.
#53
Cliff
#54
#55
I wouldn't scrap it because of fuel delivery issue. Retrace your steps. It will be something simple.
#56
Mechanicals don't regulate, they pump the same PSI continuously until you punch it in which case the faster pumping (I think) would increase the quantity and gas to meet the need of the engine. The only way to change PSI is if you had a different pump. I can adjust my pump because it's electric and I built in a regulator.
You can't scrap it. You're just having old truck problems. Once you get through it, you'll be the happiest guy in the world. Especially when you catch that dude on the interstate checking your truck out!!! From what I can figure out, volcano carb is occurring because fuel is flowing uncontrolled into the bowl and out of places it should not be flowing. So its got to be fuel PSI, needle, float sinking, wrong float adjustment, the little doohickey the needle seals against.......and that's all I can think of right now.
#57
Cliff is right. With Carburetors 99% of the problems you have make you feel like a total loser once you've cured them. You wanna stamp the big "L" in the middle of your forehead to save people the trouble. And in my case, you usually end up with a lot of spare parts you thought were busted which come in handy down the road.
#58
I hate to tell you, but it is something wrong with the float system. You are going to have to keep messing with it till you figure it out.
I have done the same as you, and had the same problem, and after I took the carb apart and pulled the needle out, I looked down in where the needle went and there was a little chunk of rubber down blocking it from closing. The fuel line I had made had a sharp place on it, and just by sliding the new piece of fuel line up on the metal line, it had shaved a little chunk of rubber off the line and that had gotten up in there and fouled it up.
I would take it apart again, for some reason the float/needle system is not working.
